HI, managed to make a full scan last night but unfortunatelly the wi-fi didn't work so i couldn't copy the files in a nice way to read instead i took as last resort the option to make a photo for each module. Hope this can help out, many thanks again fro the help here
r4nd0mize (1st February, 2022)
Ok, from your scans/screenshots your software part number is 1K0907379BH. So here you go: 113B401C09220002881102E5901E0042300000
One information was missing: engine start stop yes/no. But that was rare back in that days so I turned it off. So if you don't have engine start stop in your car this is just fine. Otherwise coding needs to be fixed.
Have a good one.
Ok, so as I expected your first posted VIN was wrong. There is no "12" in the middle, it is "1Z". Redardless of that posting the sticker is not always a good idea cause recently there was a user having a modified vehicle but posted VIN from sticker (VIN in ecu and immo was different, so generated coding was not working). Therefore only the VIN in the scan is relevant and important.
So first: please confirm the VIN on sticker is same as in the scan.
Second: please provide more information, as it is not enough to recreate what you posted before. You can use the previous users post (Florin7) as example. But add the information whether the car has engine start stop or not.
Hi, could you calculate a long abs code for me? I purchaced a damaged repairable skoda yeti and it had far more wrong with it than i knew. Insrument cluster was dead so was unaware.
Got that repaired only to find that abs light, EPS light and brake light were all on. When I checked the system there was no ABS long code. From live data all pressures and sensors are functioning correctly.
I purchased a code on line and although it didn't want to upload at first it did eventually but has made no difference. Before I do anything drastic with it I was just hoping you could check the code I got.
The Vin is TMBKF75L3B601579
1.2 PETROL RHD
No tire sensors
The code I am using at present is
933F200E092301FFC91204E790228081300000
Thanks for any help you can offer
Identification of your ABS system? Software part number? Scan? Besides that I need to know what to compare with to say if it is ok or not, meaning, what is the current setup of the car.
I don't get the problem really. You bought a coding but it seems to be wrong? Where is it from, then?
Regards.
Its a MK60 EC1 Software number 1K0907379AT, I purchased the code from carprogonline.com and uploaded it with delphi
Sorry to ask. But if it is wrong and you purchased it from carprogonline, why don't you request or at least demand money back there?
What you use to write the coding (in this case delphi) does not matter at all. You can use anything, it's just fine.
But if you want me here / anyone here to get this fixed please let us know the regular information it needs (check previous requests as an example).
By the way I checked you coding and here are some (not all) of the information carprog coded...
- skoda yeti
- smallest front brake
- rear brake is disc
- right hand drive
- right hand drive brake booster (the doubled small one)
- engine start stop: no
- no tpms
- no hillhold
- no xds
I don't know your engine so I have no clue if brakes and stuff is correct... Neither do I know what problem you have cause if this coding was accepted, but still wrong, you will not notice it being wrong.
So if you want proper you have to leave the information here I asked for.
//edit: don't let it sound harsh, but the VIN you offered here (TMBKF75L3B601579) is not a valid VIN. It is only 16 characters long. Don't wanna say this makes me mad or pissed,... but actually... yea it does. You ask for help, and we provide help free. But things like that make us run into nowhere. Took my time to reanalyze from your current coding and your VIN should be TMBKF75L3B6015739, so you missed one number and provided false information. I am a little tired so it may happen I won't respond on requests here that often in the future anymore (or even stop doing it). So please excuse but it's mostly because of things like that. Just attach a scan and problems like that do not appear. Thank you. This is my spare time. I am sorry.
Stirling Moss (2nd February, 2022)
Thank you for the help you offered. I am new to this forum, in fact I have never joined any forum before, this as well as ABS long codes are all new to me and I am trying hard to learn as I am unemployed I can't afford to put the car in to have it repaired so it was either try and learn fast or scrap the car. This forum is obviously the wrong place for me and you don't need to worry about me posting here and disturbing you again. Once again, thanks for your help and sorry for wasting your time.
r4nd0mize (2nd February, 2022)
As I said, it was not about to be meant offending even though it might sound harsh, but please understand that nobody here can help if you post a wrong/invalid vin. And that it is not really understandable what exactly the problem is as there is no scan attached and your description only says that lamps are on. If it is about the coding it is fixable, but it needs your (correct) information about the vehicle.
Please just understand that when trying to help and then after a while noticing that provided vin is wrong does not make someone feel happy about the time already spent.
Besides that I posted most significant options that are set in your coding you got from carprog so you could just compare with the vehicle you have there and reply with the information needed and the problem will very likely be solved here. That plus a scan and I think it's solvable in a short time whenever someone or me has the time to take care of it.
The forum is probably exactly the right place - but everyone should respect that almost every user is using his spare time to help so in my opinion the least someone requesting help can do is offering as much information as possible or provide information when asked.Cause that keeps the amount of time a user needs to provide help at a minimum.
Hello everyone.
I am having a problem with the ABS/ESP. And I would need to check if the coding is correct. Here I pass you the vehicle data along with the fault 00003.
In the Ross-Tetch video it says to do it as follows:
https://youtu.be/b6lm9OmC2so
I leave you a video of what happens to me when I try to do the basic settings of 025 and 026:
https://youtu.be/VvGOqZyQeHA
OBDeleven Data Logging
Date: 2022-01-27 19:25:16 AM
VIN: VSSZZZ1PZAR013173
LHD
Car: Seat Leon
Year: 2010
Body type: Hatchback
Engine: BLS 77 kW (105 HP) 1.9 l
Mileage: 165540
03 Brake electronics
System description: ESP MK60EC1
Software number: 1K0907379AN
Software version: 0107
Hardware number: 1K0907379AN
Hardware version: H45
Long coding: 113B2012092300FD880C04EB901C00413400
Error codes:
00003 - Control unit No basic setting or adaptation or wrong.
static
Your problem basically is the basic setting itself. Sometimes it's tricky. But missing basic setting is definetely NOT related to anything inside the coding. So you should focus on why the basic settings fail.
If you want the coding to be checked. Let us/me know. If you have doubts about your coding it must have a reason (where is it from?). To verify if it is accurate/correct, it needs more info about the vehicle anyways. All I can say by now is, that it looks good for a left hand drive, smaller engined vehicle (petrol or small diesel), with tire pressure monitoring on. If that is the case you should not worry about that.
aolvera (4th February, 2022)
