Page 238 of 245 FirstFirst ... 138188228233234235236237238239240241242243 ... LastLast
Results 3,556 to 3,570 of 3668
  1. #3556
    Dec 2010
    Earth
    Quote Originally Posted by Jonatanfunes91 View Post
    please help
    What are:
    1. Driving side
    2. Engine type
    3. Transmission Auto or Manual
    4. Suspension: Standart or Sport
    5. Start-Stop
    6. TPMS button or monitoring
    Getting correct ABS coding is simple:
    1. Get a photo of the sticker with PR codes from the trunk spare wheel or decode VIN https://carinfo.kiev.ua/vin
    2. Get VCDS scan
    3. Post the info above on the forum and please also describe where steering wheel is located (LHD/RHD), presence of Start-Stop system, buttons: TPMS/RKA, ESC/TCS/ASR off
    Good to know: without option's list/current car scan/details about driving side etc, the proper coding is not possible in 99% of cases!
  2. The Following User Says Thank You to lprot For This Useful Post:
    Jonatanfunes91 (20th June, 2022)
  3. #3557
    Jonatanfunes91's Avatar
    Jun 2020
    Argentina
    Quote Originally Posted by lprot View Post
    What are:
    1. Driving side
    2. Engine type
    5. Start-Stop
    hello thanks for reply 1) left side 2) 1.4 3) Standard 4)common key 5) if it has tpms sensor Is this information useful my friend?
    :wink
  4. #3558
    Dec 2010
    Earth
    Calculation for LHD, front brakes 288mm, rear 232mm, standard suspension, manual transmission, CAXA 1.4TSI, Start-Stop, Hill Hold Control, XDS:
    310448E9217500BB8C2712EA84D800510D00
    without Start-Stop it would be 310448E9217500BB8C2712EA84D800410D00
    Let's play with Tire Pressure Monitoring options later if one of these codings is accepted? I wonder if the car has a sticker with PR-Codes in the trunk near spare wheel.
    2. Get VCDS scan
  5. The Following User Says Thank You to lprot For This Useful Post:
  6. #3559
    Jun 2020
    Argentina
    thank you very very much. I'm going to fix the label on Wednesday to see if it brings it. Thanks a lot
    :wink
  7. #3560
    Jun 2022
    Hey, Im new hear and i have a problem,
    I have an MK60 EC1 and he lost the long coding
    pls help me.
    Audi S3 8P 09.2008
    WAUZZZ8P59A034586
    2,0 TFSI
    1K0 907 379 AP
    ESP MK60 EC1 H450109
  8. The Following User Says Thank You to Mert93 For This Useful Post:
    lprot (20th June, 2022)
  9. #3561
    Dec 2010
    Earth
    Quote Originally Posted by Mert93 View Post
    pls help me.
    Audi S3 8P 09.2008
    WAUZZZ8P59A034586
    2,0 TFSI
    1K0 907 379 AP
    As there is no scan I guess that car is RHD? If there was AE block from the stock and it was not reflashed to CE then try:
    16428012092500FE681001EC901F00813800
    If AE was officially reflashed to CE and now you instlled AP then:
    16428012492500FE681001EC921F00813800
    Don't forget to do basic settings http://wiki.ross-tech.com/wiki/index...1)#Replacement
    And after that you can additionaly turn on Hill Hold Control in bit0 of byte 16.
    Don't forget to give feedback which coding worked. Good luck!
    2. Get VCDS scan
  10. The Following User Says Thank You to lprot For This Useful Post:
    Mert93 (20th June, 2022)
  11. #3562
    Jun 2022
    it is a LHD. I don't change the ABS block, it was always an AP. He only lost the coding because the battery voltage was too low. The only thing we did is flash the version of H45 0107 to the latest version H45 0109. Here is a picture before flashing the software.Thanks in advance
    Attachment 895119
  12. #3563
    Jun 2022
  13. The Following User Says Thank You to Mert93 For This Useful Post:
  14. #3564
    Dec 2010
    Earth
    Then try 14428012092500FE281001EC901F00413900 and please also show coding of block 19.
    2. Get VCDS scan
  15. The Following 2 Users Say Thank You to lprot For This Useful Post:
  16. #3565
    Jun 2022
    ok thanks, i will test it
  17. The Following User Says Thank You to Mert93 For This Useful Post:
  18. #3566
    Dec 2010
    Earth
    Just in case it does not accept the first one, also try 14428012492500FE281001EC921F00413900 but I beleive the first one is the correct one
    2. Get VCDS scan
  19. The Following User Says Thank You to lprot For This Useful Post:
    Mert93 (21st June, 2022)
  20. #3567
    Mar 2014
    Well I was blind and forgot that SET RDW/RKA button on MFA+/MaxiDOT cannot be handled by AD and that's why bit 1 of byte 16 should be disabled too. So taking into consideration all the nuances (1AT code, AD version, no HHC possible, no RDW/RKA SET button handling possible) the proper coding is: 114B400C492300FD880B02E8921A00413400
    I wonder will flashing to CD add compatibility with SET button?
    I also beleive you underestimate importance of break system config in byte 4 that configures suspension type etc. I do not mean brake discs config is stored in this byte. There are alot of cases when firmware does not accept correct coding because of mismatch between the value you want to set with the hardcoded fw value. I beleive reflashing to the latest fw version solves that.
    114B400C492300FD880B02E8921A00413400 Worked correctly. I thank you kindly.
  21. The Following User Says Thank You to Workshop2 For This Useful Post:
  22. #3568
    number7hd's Avatar
    Dec 2013
    Need ABS coding.
    THANKS !!!!
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 06314 123 12345
    VCID: 74E769D7D7BB262955-8020
    If my solution helped You - do not forget to THANKS !!!
  23. The Following User Says Thank You to number7hd For This Useful Post:
    gege974 (24th June, 2022)
  24. #3569
    gege974's Avatar
    Oct 2018
    réunion island
    salut
    voici votre codage
    11422012092700fb881404e8902100423800
    Small circumstances produce great events : 02.47-tranquillité:
  25. The Following User Says Thank You to gege974 For This Useful Post:
    number7hd (24th June, 2022)
  26. #3570
    Oct 2017
    99problems
    Quote Originally Posted by number7hd View Post
    Need ABS coding.
    THANKS !!!!
    Revision: 00H35001
    get a try on this
    left hand drive, no tpms, no hill hold
  27. The Following User Says Thank You to ilzul For This Useful Post:
