cheero (12th August, 2022)
Getting correct ABS coding is simple:
1. Get a photo of the sticker with PR codes from the trunk spare wheel or decode VIN https://carinfo.kiev.ua/vin
2. Get VCDS scan
3. Post the info above on the forum and please also describe where steering wheel is located (LHD/RHD), presence of Start-Stop system, buttons: TPMS/RKA, ESC/TCS/ASR off
Good to know: without option's list/current car scan/details about driving side etc, the proper coding is not possible in 99% of cases!
button for TPMS not in car, TPMS LED show in dashboard, you have right
++++ GOOD WORK ? + ++++
FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
2. Get VCDS scan
Hi mate, i try it insert your first code - 113B201C092700FB880D04EC901B00416800
and all is OK, working good !
Very thxy mate, you are BEST !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hola buenas me pueden decir codigo largo abs golf gti vi 2009 1k0907379am esp mk60ec1 vin wvwzzz1kzaw039066 por favor ayudenme
2. Get VCDS scan
It is very commendable when the Russians help solve problems. They even started to mention you at home))).
Try not to search, but count from 143Bxxx yes there are 60 wheels, cars from Germany. Read the code, I will help if you make a mistake. Glory to Ukraine!
No need to steal someone else's, as the katsaps always did. If you don't have the code tomorrow, you'll have to write it to me.
Hello i need long coding please
WAUZZZ8V8FA131291
2015 a3 sportback 2.0 Tdi 150 6gear manual and not quattro
3Q0-907-379-AF
LHD , 1KE, 1ZE, G35, tyre pressure in dashboard only, electric brake hand, servotronic steering, start and stop, hold assist, and hill start
park assist only at the back
thank you…
Во-первых, на MQB второго поколения стали устанавливать А3 с блоками ЗЧ. И писать PR-коды для таких блоков глупо.
Не надо показывать пиар-лейблы, они важны только для кацапов. Все уже понимают, что есть турбодизель 2.0, с коробкой 6S
не думаю, что в Испании не догадаются, как сделать автоскан.
Почему я задаю много вопросов, ведь вам нужен еще один блок, с буквой Q. Объясните, была ли замена или вы хотите сделать
ракету?
на 8В отдельный тип тормозных блоков. Они отличаются радикально. Вы запрашиваете большую строку кода, хотя для вашего автомобиля требуется другой блок. Я в шоке)))
do me a scan of block 03 and I will try to help you.
Firstly, they began to install A3 with AF blocks on the second generation MQB. And writing PR codes for such blocks is stupid.
No need to show PR labels, they are important only for katsaps. Everyone already understands that there is a 2.0 turbodiesel with a 6S box
I do not think that in Spain they will not guess how to make an autoscan.
Why do I ask a lot of questions, because you need another block, with the letter Q. Explain whether there was a replacement or you want to do
rocket?
8V is a separate type of brake blocks. They differ radically. You are asking for a large line of code even though your car requires a different block. I'm shocked))
I'm sorry, my browser works as a translator by itself, bitch)))))
Thank you so much for the disc tips. but I advise you to listen and insert the log of the car. Last time I ask, do it, do not argue.
yes i understand, but im not with the car, in 30 minute i can
If you want to do it proper - calculate yourself https://docs.google.com/spreadsheets...Q1V1qpXOTBX84/
I adjusted the conding from this A3 https://forums.ross-tech.com/index.php?threads/30797/ for your VIN so that will be a good start:
12F162A224230A6D0379060941C42948462450C0608294F718 41507886A8
Remove the space from coding when copy/pasting as forum adds it somehow.
Errors in block 3 will tell you if anything is wrong here as MK100 block is the easiest to code.
2. Get VCDS scan
Do not read this katsapsky jerk. They can only steal and kill. Throw off the log in a personal or on the forum, I will calculate the code with my calculator. Glory to Ukraine!
Blocks 5Q0xxxxx and 3Q0xxx were installed on these cars. They support different functions. I see your car, Spain. Or the Canary Islands. Let's log, I'll count, rusishvay goes to hell.
I see a log from the bottom, I went to make coffee. I'll post a draft a little later.
Mardi,16,Août,2022,22:01:05:30835
Version VCDS: FRM 12.12.1
Adresse 03: Freins ABS Labels: Aucun
No. VAG du calculateur: 3Q0 907 379 AF Mat: 3Q0 907 379 F
Pièce et/ou version: ESC H42 0625
Codage logiciel: 00000000000000000000000000000000000000000000000000 0000000000
Code atelier: WSC 06314 790 00021
Jeu de données ASAM: EV_Brake1UDSContiMK100IPB 034036 (AU37)
VCID: 7EF30811E18F06EEE65-802B
14 Codes défaut trouvés:
0195 - Calculateur non codé
U1013 00 [137] - -
Témoin allumé - Confirmé - Testé depuis RàZ mémoire
Capture:
Etat du défaut: 00000001
Priorité du défaut: 2
Fréquence du défaut: 1
Compteur de RAZ: 228
Kilometrage: 210074 km
0212 - Capteur d'accélération longitudinale
C1017 54 [137] - Calibration manquante
Capture:
0270 - Transmetteur d'accélération transversale
C1079 54 [137] - Calibration manquante
Capture:
0279 - Transmetteur 1 de pression de freinage
C107A 54 [137] - Calibration manquante
Capture:
0295 - Transmetteur d’angle de braquage
B1168 54 [137] - Calibration manquante
Capture:
0297 - Transmetteur d’angle de braquage
B1168 16 [008] - Tension trop faible
Intermittent - Confirmé - Testé depuis RàZ mémoire
Capture:
Fréquence du défaut: 5
Compteur de RAZ: 22
Kilometrage: 210238 km
Date: 2022.08.16
Temps: 14:49:00
4161 - Codage non valable
U10DA 00 [137] - -
Capture:
Fréquence du défaut: 3
Compteur de RAZ: 238
Kilometrage: 210067 km
Date: 2022.08.13
Temps: 13:20:23
8306 - Bus de données
U1122 00 [137] - message non plausible
Capture:
Date: 2022.08.13
Temps: 12:54:11
8308 - Calculateur mal codé
U1014 00 [009] - -
Capture:
Priorité du défaut: 3
Fréquence du défaut: 45
Date: 2022.08.16
Temps: 14:49:00
8314 - Contrôler code/variantes des Calculateur ds la ligne de transmission
P1647 00 [009] - -
Capture:
Fréquence du défaut: 48
Date: 2022.08.13
Temps: 12:54:09
16412 - ROD - Code défaut inconnu
- 00 [008]
Capture:
Compteur de RAZ: 13
Date: 2022.08.13
Temps: 12:39:42
16413 - ROD - Code défaut inconnu
- 00 [008]
Capture:
Compteur de RAZ: 13
Date: 2022.08.13
Temps: 12:39:42
32848 - Calculateur de frein de stationnement électromécanique
C10E2 F1 [137] - Elaboration d'erreur inconnue
Capture:
32951 - Calculateur de frein de stationnement électromécanique
C10E2 54 [137] - Calibration manquante
Capture:
