1: Control Module Part Number: 1K0 907 379 AP
2: car VIN -WVWZZZ1KZAW160332
3: model : 5K1
4: LHD
5: 1.4 TSI
6: FWD
7: no start stop
8: no TPMS
9: yes ESP button
10: no Hill hold
Can you help me for Long Code
Hello friends! I need help with the long code of a VW, who suffered decoding when trying another dashboard on the vehicle. From already thank you very much! regards!
ECU:
HW: 0261S04612
SW: 1037399540
VIN: 3VWRG61K08AM036990
ABS: 1K0614517BD
MODEL:
JETTA 2.5L
YEAR 2010Hello friends! I need help with the long code of a VW, who suffered decoding when trying another dashboard on the vehicle. From already thank you very much! regards!ECU:HW: 0261S04612SW: 1037399540VIN: 3VWRG61K08AM036990ABS: 1K0614517BDMODEL:JETTA 2.5LYEAR 2010
3: model : 5K1
4: LHD
5: 1.4 TSI
6: FWD
7: no start stop
8: no TPMS
9: yes ESP button
10: no Hill hold
GOLF 6
LHD
2.0 TDI 81 KW
VIN
WVWZZZ1KZ9P475951
ABSMODUL
ESP MK60EC1
1K0907379AD
tpms
somebady help
3: model : 5K1
4: LHD
5: 1.4 TSI
6: FWD
7: no start stop
8: no TPMS
9: yes ESP button
10: no Hill hold
113B200D092800FA880E04E7901B0040300000
TRY THIS AND REPORT .
Hi.
Please help .
VW golf VI 2010r
1,4 tsi
ABS 1K0 907 379 AH ESP MK60EC1
solved calculated the coding
Last edited by kowalskidebno; 16th December, 2018 at 07:10 PM. Reason: solved calculated the coding
hI ,PLEASE HELP FOR LONG CODING
AUDI A3 2006
MOTOR 2.0 FSI BVZ
VIN WAUHS38P36A218353
ABS 1K0614517AC CTA ESP
There is a short ABS coding in your Audi A3 !!!
ABS/EDS/ASR/ESP (MK60)
- Model:
- +0000000 = Audi A3 (8P) / Seat Leon (1P) / VW Golf/Jetta (1K) / Skoda Octavia (1Z)
- +0000064 = VW Touran (1T)
- +0000080 = VW Caddy (2K)
- +0000096 = VW Eos (1F)
- +0000112 = Seat Altea/Toledo (5P) / VW Golf Plus (5M)
- Frontbrakes (Sensor Cluster OLD):
- +0000005 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
- +0000006 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
- +0000009 = FRNG 57 17" (PR-1LK)
- Frontbrakes (Sensor Cluster NEW):
- +0000001 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
- +0000002 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
- +0000008 = FRNG 57 17" (PR-1LK)
- Suspension:
- +0000640 = Standard/Sport Suspension (PR-2UA/2UC OR PR-UA0/UA1/UA9)
- +0001152 = Rough Road/Comfort Suspension (PR-2UB/2UD OR PR-UA2)
- Engine:
- +0002048 = 1.4l / 1.6l & 1.6l FSI
- +0004096 = 1.9l TDI PD / 2.0l FSI / 2.0l SDI PD & All with Automatic Transmission
- +0006144 = 2.0l TDI PD
- Tire Pressure Monitoring (TPMS):
- +0000000 = with ABS based Tire Pressure Monitoring (PR-7K1/7K6)
- +0016384 = without ABS based Tire Pressure Monitoring (PR-7K0/7K4/7K8)
Notes: See production codes on car data plate. Coding is the sum of the individual options.
Sensor Cluster OLD: Installed behind glove compartment (ONLY VW Caddy (2K) & VW Touran (1T) & Audi A3 (8P) <MY2005).
Sensor Cluster NEW: Installed under passenger seat (All Others & Audi A3 (8P) MY2006>).
Special Notes: When replacing 1K0-907-379-D with 1K0-907-379-K or newer, the original Coding CANNOT be transferred to the new Control Module. Instead you need to build a new Coding using the Table above.
pleas write coding
0021206
Can some one help me with gearbox conversion from 7 spd DSG to 5spd manual:
VW Caddy 2013
Engine 1.6tdi
FWD, RHD
ABS: 1K0 907 379 BL ESPMK60EC1
Ori codding - DSG gearvox: 633C400D092A03FFC60C02E5901FC081310000
I need to get rid of DSG and putt 5 speed manual gearbox into the coding please.
Big thanks
The ABS coding in fact has nothing to do with the fault you are getting, seriously....
You need to reflash your Engine ECU with a flash/sgo for manual trans and all will be fine
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
borysgo2 (4th January, 2019)
Hello friends I have big problem with my Golf VI ABS MK60EC1. I have changed the whole unit because old one was damaged. Before that I have read the original coding : 1462401A094A00222833020C904100403000. After replacing the unit I tried to code it with my original coding but it is rejected ... I tried few more codings but nothing works. Can you give me a helpful hand ?
My car is :
VW Golf VI 1.4 tsi, fwd, LHD
vin : WVWZZZ1KZ9P465580 ; ABS pump : 1K0907379AD
Greetings
please help with the following
VOLKSVAGEN JETTA 2011 1.6 TDİ
MK60EC1
1K0907379BE
LHD
DSG
WVWZZZ1KZBM043319
MK60EC1
1K0907379BE
LHD
DSG
WVWZZZ1KZBM043319
kamolsfss (11th September, 2019)
