Page 157 of 245 FirstFirst ... 57107147152153154155156157158159160161162167207 ... LastLast
Results 2,341 to 2,355 of 3668
  1. #2341
    Feb 2020
    Please Help ! I need ABS Long coding Skoda Octavia
    VIN: TMBBS61Z772089101
    Regards !
  2. #2342
    lucic66's Avatar
    Aug 2015
    Test,113B001C092A0003000C00E4901A0000000000.
    Quote Originally Posted by eranta View Post
    Regards !
  3. #2343
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by Panathaole View Post
    hi
    i need correct long coding after abs pump replaced.... HW: 1K0 907 379 AH
    full scan via vcds
    Thank you...
    Attachment 691139
    No one can help?
  4. #2344
    Top Poster vankoal's Avatar
    Jan 2010
    Bulgaria
    Can anyone help ?
  5. #2345
    lucic66's Avatar
    Aug 2015
    Test,114B000C092B00FF001000E790220000000000.
    No one can help?
  6. #2346
    lucic66's Avatar
    Aug 2015
    Test,114B000C09280000000C00ED901E0000000000.
    Quote Originally Posted by vankoal View Post
    Can anyone help ?
  7. The Following User Says Thank You to lucic66 For This Useful Post:
    vankoal (18th February, 2020)
  8. #2347
    Jan 2010
    Bulgaria
    Thanks but it doesn't work. Code rejected: 31
  9. #2348
    andkl2810's Avatar
    Aug 2012
    SLAVA UKRAINI !!! GEROJAM SLAVA !!!!
    Hi guys !
    skoda 2.0TDI TMBCE61Z3AC006227
    REGARDS!
  10. #2349
    Jan 2010
    Bulgaria
    Problem solved.
  11. #2350
    Mooti's Avatar
    Nov 2018
    Quote Originally Posted by andkl2810 View Post
    Hi guys !
    REGARDS!
    113B001C09220000880D00E690200000000000
  12. #2351
    Nov 2019
    Octavia RS 2,0 TDi, LHD, TMBUH61Z092039778, ABS is 1K0 907 379 AP
    Please help with long code
  13. #2352
    Dec 2019
    Quote Originally Posted by binhr21 View Post
    Hi!
    I would like to say thank you people for helping me & Please can you give me a coding for this ABS:
    my old abs (1k0 907 379 bk) I replace it with (1K0 907 379 BL)
    Volkswagen Passat Sedan 2014 New Passat (HIGHLINE)
    Thursday,20,February,2020,15:14:30:14601
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: WVWCR7A37EC000894 License Plate:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 1C 25 2B 2E 42 46 47 4F 52 56
    62 72 77
    VIN: WVWCR7A37EC000894 Mileage: 104330km-64827miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
    Part No SW: 07K 906 055 CB HW: 07K 907 309 B
    Component: 2,5L 125KW G01 1202
    Revision: T4H06--- Serial number:
    Coding: 0000075
    Shop #: WSC 09003 957 00200
    VCID: 70ACF6C7639A1ACF57-8024
    1 Fault Found:
    001393 - Brake Switch (F)
    P0571 - 000 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 104337 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 16:18:34
    Freeze Frame:
    RPM: 790 /min
    Load: 33.7 %
    Speed: 7.0 km/h
    Temperature: 56.0°C
    Temperature: 24.0°C
    Absolute Pres.: 1020.0 mbar
    Readiness: 0010 0001
    Address 02: Auto Trans Labels: 09G-927-750.clb
    Part No SW: 09G 927 750 NH HW: 09G 927 750 NH
    Component: AQ 250 6F 2244
    Revision: 00H97000 Serial number:
    Coding: 0000328
    VCID: 0444AA174722166F83-8050
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 00028 028 00001
    VCID: 7DB2DFF3E4C867A7CC-8028
    5 Faults Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 320
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:56
    Freeze Frame:
    Count: 7
    Count: 14
    Count: 29184
    Count: 195
    Count: 48640
    Count: 10496
    Count: 65280
    Count: 8704
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 279
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 295
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 270
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
    Part No SW: 5K0 959 434 B HW: 5K0 959 434
    Component: VWKESSYPQ35GP 086 1101
    Revision: 00086000 Serial number: 0199297623
    Coding: 030C0C
    ASAM Dataset: EV_KESSYPQ35G A02013
    ROD: EV_KESSYPQ35G_A02_VW31.rod
    VCID: 34243AD79F0266EF73-8060
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 561 907 044 R HW: 561 907 044 R
    Component: Climatronic H03 0405
    Revision: 00001K01
    Coding: 0010001002
    ASAM Dataset: EV_ACClimaBHBVW411 A01001
    ROD: EV_ACClimaBHBVW411_VW41.rod
    VCID: 2600D09F59DE047FFD-8072
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
    Component: BCM PQ35 M+ 021 0068
    Revision: BD021001
    Coding: 68200E3B802908D400080000340081E00371008645A00DF064 806000AC70
    VCID: 41CA6303D8B0C347E8-8014
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 050213 05 54 0403
    Coding: 02300A
    1 Fault Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 124
    Mileage: 104337 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 16:07:16
    Freeze Frame:
    Term 15 On
    Voltage: 11.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
    Component: AirbagVW10G 014 0851
    Serial number: 003MWM01FAJ
    Coding: 00005033
    ASAM Dataset: EV_AirbaVW10SMEVW360 001026
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 75A2C7D3D4F83FE784-8020
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
    Component: BF-Gewichtss. H10 0046
    Serial number: 6940000Y130000SJJ20$
    Coding: 303046
    Crash sensor for side airbag: driver side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H02 ----
    Serial number: 3572MSME71266578ZZZZ
    Crash sensor for side airbag: front passenger side:
    Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H02 ----
    Serial number: 3582MSME7E6F1478ZZZD
    Crash sensor for side airbag: rear: driver side:
    Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Fahr.H H02 ----
    Serial number: 3516KSME46746822ZZZS
    Crash sensor for side airbag: rear: passenger side:
    Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Beif.H H02 ----
    Serial number: 3526KSME632A3F22ZZZX
    Crash sensor for front airbag: driver side:
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Fahr H02 ----
    Serial number: 3556LSME28703921ZZZQ
    Crash sensor for front airbag: front passenger side:
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Beif H02 ----
    Serial number: 3566LSME724C3921ZZZZ
    1 Fault Found:
    9439771 - Front Passenger's Side Airbag Igniter
    B100A 1B [137] - Resistance Too High
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 104337 km
    Date: 2020.02.12
    Time: 16:06:13
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 1K5 953 501 S HW: 5K0 953 569 L
    Component: LENKS.MODUL 014 0140
    Revision: FF010041 Serial number: 20121125100110
    Coding: 010A140000
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    ROD: EV_VW360SteerWheelUDS.rod
    VCID: 3B3611EBB25CA997B2-806E
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-YVJ H07 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
    Part No SW: 561 920 870 B HW: 561 920 870 B
    Component: KOMBI H07 0705
    Serial number: 00000000000000
    Coding: 631E01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 187CEE67E3AAA28F7F-804C
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
    Component: J533 Gateway H50 1634
    Revision: H50 Serial number: 02041303290542
    Coding: 461000
    Shop #: WSC 12345 123 61029
    VCID: 76A0C0DFC1FE34FF8D-8022
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 561 919 965 HW: 561 919 965
    Component: Kompass 002 0001
    Revision: 00002000 Serial number: 1829227R44D406
    Coding: 0000002
    VCID: 6386898BA26CB157DA-8036
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H07 0705
    Serial number:
    Coding: 000007
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6A98E4AF8D46E01F19-803E
    Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
    Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
    Component: ELV-PQ35 H21 0240
    Revision: 00000000 Serial number: 13000003861002
    Coding: 4900000000000000
    ASAM Dataset: EV_ELVMarquMPVW36X A01001
    ROD: EV_ELVMarquMPVW36X.rod
    VCID: 302C36C76B1A5ACF17-8064
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H19 0550
    Revision: A1001003 Serial number: 7664509691
    Coding: 010100
    VCID: 2A1824AF45C6201FD9-807E
    Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0525
    Revision: 13110009 Serial number: 0006474867
    Coding: 0404FD
    ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
    ROD: EV_TSGFPQ25BRFVW46X.rod
    VCID: 5BF6B16B521C899792-800E
    Slave Driver:
    Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG_HL 006 5470
    Serial number: 14202630130410104818
    Coding: 800000
    1 Fault Found:
    131584 - Motor for Rear Window Regulator
    B11EE 54 [008] - Missing Calibration / Basic Setting
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 165
    Mileage: 104337 km
    Date: 2020.02.12
    Time: 16:06:15
    Address 47: Sound System (R12) Labels: 5K0-035-456.clb
    Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
    Component: KonzernAmp10K H07 6813
    Revision: -------- Serial number: EAA098A0034290
    ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
    ROD: EV_AudioVerst10KanalSTT3.rod
    Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
    Component: EZE_2 H50 1634
    Coding: 01030108
    VCID: 6FAEF5BBBEA405374E-803A
    Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
    Component: J245 P05 FFD7 H07 0004
    Serial number: 53388786011232400873
    Coding: 181100
    Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
    Component: Analoguhr 008 0005
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0525
    Revision: 15110009 Serial number: 0006500806
    Coding: 0404FC
    ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
    ROD: EV_TSGBPQ25BRFVW46X.rod
    VCID: 5CF4B27757128EAF9B-8008
    Slave Passenger:
    Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG_HR 006 5470
    Serial number: 14202631130409180554
    Coding: 800000
    2 Faults Found:
    67074 - Motors for Central Locking
    B122B 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 165
    Mileage: 104337 km
    Date: 2020.02.12
    Time: 16:06:18
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
    Component: Radio RCD510 051 0213
    Revision: 00000001 Serial number: VWZ1Z3M8406516
    Coding: 0102004001000B
    VCID: 2306C98B22ECF1579A-8076
    Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
    Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007664291009
    Coding: 0A00000000010110
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_002.rod
    VCID: 3A3814EFBD66909FA9-806E
    End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    please can somebody help with abs codig for my car
    thank you
    can some one help me with my issue please.
  14. #2353
    Feb 2020
    hi
    can you help me i have skoda fabia some one repleaced abs pump and now its wrong codding.
    TMBFA6NJ8JZ195399
    Pump is 6CO-907-379-R
    Thank you
  15. #2354
    Dec 2019
    I managed to solve my issue by myself.
  16. #2355
    Default Vw Golf 6 abs long coding
    Hello
    Vw Golf 6 fault in dash replaced with donor dash, engine ecu and key transponder lost abs long code
    vin from donor dash is WVWZZZ1KZ9W470776
    abs mk60eci 1K0907379 CD
    engine tdi cbdc
    rhd
    5 speed manual gearbox
    fwd
    no start stop
    no tpms
    esp in centre console
    no hill hold
    help with new long code appreciated
