Page 3 of 14 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 196
Thread: Vagtacho 3.30
  1. #31
    pt
    Quote Originally Posted by vares View Post
    zecas
    Have you tried to read atmega8 with programmer?
    yes but it is locked like vag-com are
    i have stk500 maby there exist some procedement to unock it
    in my opion atmega dump from 3.01 is still good for 3.40 only ept changed (i think)
  2. #32
    Where can i get the 3.01 atmega dump?
  3. #33
    I'll try it-hope it works
  4. #34
    I will also try this!!
  5. #35
    Member Tommy123Tommy's Avatar
    Quote Originally Posted by zecas View Post
    Hello
    i have clone version from ebay v3.01 i did use new version 3.40 with it but it didn't block the interface actually ID function did work but for all other functions i get message contact kitti for upgrade.
    if someone knows a way arround this dont hessitate to let me know
    regards
    Please use mprog and put ept file here please .
  6. #36
    cables after 2.50 use 93s not 93c so you need to read the hex file and and swap it .
    i have 3.30 with crack somewhere i will post it when i find it .
  7. #37
    pt
    Quote Originally Posted by Tommy123Tommy View Post
    i will post ept when i get back home at the end of this week.
    regards
  8. #38
    hello!
    can somebody upload me the vagtacho usb 2.2!?
    i also killed my cable with a 2.5rev .
  9. #39
    Jun 2009
    I'm sorry, but for which there is a SEARCH button?!!!
  10. #40
    uhm, i'm sorry .
    found it on my hard disk, thought i deleted it recently .
  11. #41
    now it works with 2.2.
    but i cant connect to vdo-new, only to any ecu and there i can only select between:
    program new key/clear ecu errors/read ecu info.
    when i run 2.5 afterwards, i can connect to vdo-new and all points are free, hummm. 2 hours ago and without the 2.2 update i only had errors like "unsupported command".
    however, it works .
    thank you!!!!!!!!
  12. #42
    A friend of mine had a similar problem. He has a 2.2 and killed it trying to update to a 2.5. I`ll try to help him using this tip. Thanks.
  13. #43
    Apr 2009
    I just restored my f*cked up 2.5 Interface (modded it to lycznik) I used the 2.2 "downgrade" - seems to work for me!
    Thanks to these guys that leeked the bin !
  14. #44
    HUNGARY
    Quote Originally Posted by denny_ul View Post
    Dead my interface, v3.3 soft version running.
    V3.3 infected ???
  15. #45
    Apr 2009
    Quote Originally Posted by kendtamas View Post
    V3.3 infected ???
    read dude, read...
    all standing on the previous sites..
    all above 2.5 will kill your interface, you only can downgrade to 2.2bin and it should work with 2.2/2.5 vag tacho..
