I killed my cable, too - restored to 2.2 and only the "connect to any tacho" command works, but if I close 2.2 and open 2.5 all functions work (sometimes it needs a few trys to connect or end/restart 2.5 application)
Seems a little bit weird to me, but I can (for now) live with this.. hope this helps some of you!
My cable works fine now, Using 2.5. Thanks for everyones help![]()
I have vagtacho 1.7 is it possible to upgrade my interface?
hi
here is ept (ft245rl) for 3.01 and software
the atmega8 was locked
i would like to upgrade to newer version i connect it to 3.30 but only ID function worked the rest did not work but did not break the cable so the atmega dump is probably still the same i only need ept.
regards
boson (25th October, 2023), Col19 (23rd November, 2020), stormfixed (25th September, 2021)
What is ID for this .ept or what ID shows on the main screen of program when the interface is connected??
How I have to use MProg? I always get the message "No devices found". But when I say "Scan" MProg find the device.
In this time, more stable version of vag-tacho - the 2.5.
Can you share the dump for 2.5 ?![]()
Would be interested in, too.
