Which is the ori rpm limiter?
Hi, 8000 RPM for You.
BR.
pass pm.......
[QUOTE=rapkopat;2755299]pass pm.......[/QUOTE
hi rapkopat, thanks for your help but not work, rev is 7000rpm
br
roby
Any ECM titanium pirated edition possible can't work on it.
Other question is, for it needed fuel and full reconfiguration much job
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
DashProg (27th April, 2016)
no one knows how to help me ?
expensive work
I don't checking files but im sure, it no work with more than 7200 because software deliverer -> manufacture don't prepared car to work with that much RPM's. So like i wrote there is much more work to achieve it. Basic limit is only for protection not for unlocking unlimited RPM.
You are wrong, bro. I've done many Fiats with old Magneti Marelli ECUs for rally, street race etc. and there's no need to recalibration other maps for only higher rev limit. In ori dump as above, stock RPM limiter is at 6800 RPM, but RPM axis for maps are scaled only up to 6000 RPM.
Hello good night, can you put more power in my file remaped and turn off speed limit. THANKS
I dont have de origin and i dont know how much power i have. THANKS AND REGARDS
