P0401 = 1A0868 16 bit 1x20 set to zero
P0400 = 1A0A78 16 bit 1x20 set to zero
Hallo
I want to learn how manually make dtc in pcr2.1. I know very well edc16 and edc17 but in siemens i never made it. I know how find error code but i don't have idea how find switch. If someone can help me i will be so grateful. I was trying make off P0400 and p0401 but without succes
here is example file:
Thanks for any tips
WinOLS (VW Polo (Original) as - - SM2G0M0000000).rar
Thats it? Only delete all line and will be ok? No switches like bosch ecu?
For P0400 set adress 1A0A9E (16bit) to 0000
For P0401 set adress 1A088E to 0000
mateusz1611 (24th April, 2016), Mohssine (22nd January, 2020), pike (24th April, 2016)
that metodic not full dtc off only half.
you can get P0000 or just limp mode there all is from dtc codes important if low all be good if high not help this way.
Like I was thinking, I read a little and now I know that are 2 switches to every dtc code. I checked at damos and I found where are switch blocks (start about 182382) but I don't have any idea how connect dtc code with it.
never had problems with this method! tested!
If tested ok
In SID not same to Bosch if codes is 90 there be 90 switch.
in sid can be 90 dtc and 110switch.
But very bad is in sid if 300dtc but 270 switch!!! and then is not posibol delete last 30dtc! that is crazy
i work many times for two dealers ford and all what i do on all ecu's from this group is tested
anyone can see this is my mod is ok ?
have work on hexeditor.
Like said carmageddon You have to delete all line, (22 adress but 2 are 0), You deleted only 10
hi mate where p403 adress ?
Geniuses in the world is steadily decreasing. Died in Newton, Einstein, no Steve is gone. I do not feel good about myself these days ...
