Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Apr 2016
    Question DELETE AND PROGRAMMING REMOTE MITSUBISHI ASX 2015
    Hello,
    Could you help me about how can i delete remotes of Mitsubishi asx 2015, and then programm new remotes (2).
    Actually the car have 2 remotes and i have to delete all and then programm new remotes. In FVDI show quantity 2, but cant delete for then programm news. How other advice can i use for this procedure? or maybe manual?
    Frecuency: 433mhz
    Thanks for your comments,
    autochei's Avatar
    Mar 2013
    romania
    u can t add remote
    when u program one remote others not work after u reprogram again
    Apr 2016
    Thanks for your comment, i couldnt programm any additional remote with FVDI or Skp900.
    malczykos's Avatar
    Mar 2010
    POLAND
    If you need program any additional remotes you need program transponder first. After program transponder in one procedure you should synchronize remote (press both buttons for 3 blinks, relase and press unlock 1 time, after this led shoult blink 3 times.) Good tool for this is job is original AVDI.
    Jul 2010
    X100 pro also ok, tested.
    Mar 2014
    Need help!
    Tried today to add new remote to 2012 ASX by X100 Pro and FVDI but unsuccessful.
    Old remote still working and new ones is not.
  7. The Following User Says Thank You to vitimax For This Useful Post:
    p1et (11th October, 2024)
  8. #7
    Apr 2010
    What pin you used?
    Sent from my VOYAGER2_DG310 using Tapatalk
  9. #8
    Mar 2014
    Quote Originally Posted by totalkey View Post
    What pin you used?
    PIN Code: 8A62
  10. #9
    Apr 2010
    Benzine or diesel?
  11. #10
    Mar 2014
    What pin you used?
    PIN Code: 8A62
  12. #11
    Apr 2010
    What engine? Diesel or patrol?
  13. #12
    Mar 2014
    Benzine or diesel?
    1600 benzine
    VIN: JMBXNGA1WCZ016256
  14. #13
    Apr 2010
    What market? Where you are located?
  15. #14
    Mar 2014
    This car is for Europe market - ASX(EUR)
  16. #15
    Apr 2010
    You need 8a42, try again with this code
  17. The Following User Says Thank You to totalkey For This Useful Post:
    vitimax (23rd June, 2016)
