u can t add remote
when u program one remote others not work after u reprogram again
Could you help me about how can i delete remotes of Mitsubishi asx 2015, and then programm new remotes (2).
Actually the car have 2 remotes and i have to delete all and then programm new remotes. In FVDI show quantity 2, but cant delete for then programm news. How other advice can i use for this procedure? or maybe manual?
Frecuency: 433mhz
Thanks for your comments,
u can t add remote
Thanks for your comment, i couldnt programm any additional remote with FVDI or Skp900.
If you need program any additional remotes you need program transponder first. After program transponder in one procedure you should synchronize remote (press both buttons for 3 blinks, relase and press unlock 1 time, after this led shoult blink 3 times.) Good tool for this is job is original AVDI.
X100 pro also ok, tested.
Need help!
Tried today to add new remote to 2012 ASX by X100 Pro and FVDI but unsuccessful.
Old remote still working and new ones is not.
What pin you used?
Sent from my VOYAGER2_DG310 using Tapatalk
Benzine or diesel?
What engine? Diesel or patrol?
What market? Where you are located?
You need 8a42, try again with this code
vitimax (23rd June, 2016)
