Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    twchnodictator's Avatar
    Aug 2015
    European Union
    Default EDC17 Locked Audi A5 3.0TDI HELP
    Hello mates,
    just got in my hands Audi A5 with EDC17CP04 and locked ECU by mpps (as I think) by some "chiptuner".
    Have original file (read via OBD) from this car in my hands, but what should I do to save this ECU?
    Can I write original file via Boot Mode and Galletto54?
    Thanks in advance.
    Ori file here A5 3.0TDI.rar
    Bosch
    1037510328
  2. The Following User Says Thank You to twchnodictator For This Useful Post:
    bsgruby (7th January, 2023)
  3. #2
    Oct 2011
    Boot mode is not the same file as OBD read....
    Aug 2015
    European Union
    Quote Originally Posted by kalif View Post
    Boot mode is not the same as OBD read....
    what should I do so? Any advices?
    Oct 2011
    EDC17 and obd write witch china is always problem. You must open ecu and read ecu via boot mode and compare with your obd read. Then remake file or find ori boot mode file and try it write. Better with ori tool
    Aug 2015
    European Union
    Can you help me with redoing it?
    Oct 2011
    read it via bootmode and post
  8. The Following User Says Thank You to kalif For This Useful Post:
    twchnodictator (29th April, 2016)
  9. #7
    Oct 2011
    first try write ori what you read before via obd. - Use good car charger to higher voltage -
  10. The Following User Says Thank You to kalif For This Useful Post:
  11. #8
    Aug 2015
    European Union
    I read via boot mode. Here it is a5_intflash.rar
  12. #9
    Aug 2015
    European Union
    All what I have read with eepromaudi a5 3,0dti flash.rar
  13. #10
    Oct 2011
    Some kind of tuning... who made this bad file? It is bad set
    I will try do your repair ori boot mode file....
  14. The Following User Says Thank You to kalif For This Useful Post:
  15. #11
    Aug 2015
    European Union
    I do not know who made it. I have car already with this problem. Owner wanted to make chiptuning in some garages. Quick and cheap Super profit as wee see
  16. #12
    Oct 2011
    Yes. This is really bad set tuning. The car is clever!! resists this mod and ecu dead.
    I am working on your file now....
  17. The Following User Says Thank You to kalif For This Useful Post:
  18. #13
    Aug 2015
    European Union
    I can write only flash_all. Galetto v54 gives me no possibility to write only EXT Flash
  19. #14
    Oct 2011
    This ecu does not have external flash.....
  20. #15
    Oct 2011
    You should write int flash after you receive repair file
