mate are you serious. This ecu never have problem with hot start
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
just want to try
this car drive me crazy
injectror are checked and fine, pump also, no fuel leaks, everything is fine
when is hot it cranks 30 seconds before it starts
just for try i want to modify start map
FAP Remover
try this file and let me knowWinOLS (Fiat Doblo (hot startl) - 345AD170).rar
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
ivica (30th April, 2016)
Thanks m8 but nit worked
Thanks anyway m8
FAP Remover
Won't work because It isn't problem with cranking IQ :P
What did you expected?
yes you are write m8 of course
just wanted to try
FAP Remover
