Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 54
  1. #16
    Sep 2013
    garage
    someone try to program mcu at91sam7s256 with samba ...?
  2. #17
    Apr 2014
    here you go mate...it should work.
    Pass in PM.
  3. The Following 8 Users Say Thank You to Shemek For This Useful Post:
    ADEL.KSHLAF (23rd January, 2018), andre1234567890 (14th November, 2018), azare (15th December, 2016), DieselManiac (27th February, 2017), drpeter (8th October, 2016), gregrimaster (15th October, 2017), mohammed s moha (2nd April, 2020), toha (3rd January, 2017)
  4. #18
    Apr 2014
    Mr BLACK the answer for UR question is yes but same SW versions of SAMBA has few bugs and you might end up with "device not recognised" after programming and using for a while your CarProg so better to use J-Flash for segger .
  5. The Following User Says Thank You to Shemek For This Useful Post:
    Mr BLACK (10th October, 2016)
  6. #19
    Jun 2010
    Quote Originally Posted by Shemek View Post
    Pass in PM.
    may i have a pass too please ? have the same problem , thanks
  7. #20
    Sep 2013
    Default 150428CAR00542UA.lib
    Lib file 150428CAR00542UA
  8. The Following 11 Users Say Thank You to pike For This Useful Post:
    bokilee (20th October, 2016), brodaty (12th October, 2016), habbou (24th February, 2017), Hazzard (12th October, 2016), iahim (12th November, 2016), macako6 (8th November, 2016), mitch2 (1st January, 2017), patiomkin11 (26th March, 2017), semga (10th October, 2016), shirokov (9th October, 2016), tiomilo (8th October, 2016)
  9. #21
    Oct 2016
    Sory to bother but i wantet to ask what do you gays think about carprog 9.31 chines clone and the SBB silca key progamer.
  10. #22
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by igor1110 View Post
    Gays? I tested the 8.21 clone on a VW UP 2012, the software connected to CAN got security acces reads the dash part no but then stops. Is it the A1 cable or the soft? KIA Sportage by obd works fine. I also tired to read/write a EWS3, but the cable 11 wiring isn't right, i have to look at it.
  11. #23
    Sep 2016
    hello please give me pass code
  12. #24
    Apr 2014
    try to replace mcp2515 for good one...
    ews3-why dont you use adopter A11 ews to read and write this module..?it works ok but Chinese one has bad wiring so you need to do a bit of modification...
  13. #25
    Apr 2014
    wasil37vc
    you got it now...right?
  14. #26
    Mar 2010
    Portugal
    Quote Originally Posted by drpeter View Post
    Greetings Dr. peter did you make the hardware test for the A1 cable. For the A11 here's schematic from Codecard for you to check. I think you should resolder the carprog base programmer if it is a clone it as very bad soldering and check capacitors polarity.
  15. The Following 3 Users Say Thank You to JotaB For This Useful Post:
    clico70 (16th August, 2017), drpeter (21st November, 2016), iahim (12th November, 2016)
  16. #27
    digi men's Avatar
    Nov 2013
    EU
    Hy,i need some help .
    i bought a carprog from china, cd is corupt and i need sw and activating for it, on lable is 8.21 -8.09 ,
    or if is good wat you give to drpeter ? Can i have the pass for it than .
    Thanks in advance
    Stop worrying about what can go wrong, and get excited about what can go right.
    PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
  17. The Following 3 Users Say Thank You to digi men For This Useful Post:
    iahim (12th November, 2016), mikroel (29th October, 2016), ozuque (29th October, 2016)
  18. #28
    Nov 2016
    081105CAR001773I plz
  19. #29
    Mar 2009
    Europe
    here is lib
  20. The Following User Says Thank You to maki For This Useful Post:
  21. #30
    Jul 2013
    Default 8.21 lib
    her is lib
  22. The Following 2 Users Say Thank You to petronijul For This Useful Post:
    bhpmotorsport (3rd September, 2018), kebappa (3rd November, 2018)
