V53 or v54?
V53 or v54?
weske2000 (1st May, 2016)
kospoz thanks v51
Hi, must to reprogram eept file with new and will work, see in you documents must to have it.
weske2000 (2nd May, 2016)
For v51 i can not tell.me i had problem with v53 and the solution was to install it on fresh windows you can try and i believe that will be ok
I have try make new install but same error
Make usb fix and it should start working again.
I think i have v51 how can i check this ?
Maybe possible, read it by USB using Mprog and give received data with serial number
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
Read EEPROM successful Device 0
0000 : 00 40 03 04 AD DA 00 00 80 16 08 00 00 00 98 0A @. .. .. .. .. .. .. ..
0010 : A2 0E B0 12 32 18 05 00 0A 03 46 00 54 00 44 00 .. .. .2 .. .. .F .T .D
0020 : 49 00 0E 03 46 00 47 00 54 00 65 00 63 00 68 00 .I .. .F .G .T .e .c .h
0030 : 12 03 34 00 37 00 34 00 31 00 34 00 35 00 35 00 .. .4 .7 .4 .1 .4 .5 .5
0040 : 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .4 .. .. .. .. .. .. ..
0050 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .. .. .. .. .. .. .. ..
0060 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .. .. .. .. .. .. .. ..
0070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E FF .. .. .. .. .. .. .. .^
0080 : 34 04 CB FB 00 00 06 2A A4 68 42 00 00 00 00 00 .4 .. .. .. h. .B .. ..
0090 : 00 00 00 00 00 00 00 00 4D 41 53 56 34 32 51 45 .. .. .. .. AM VS 24 EQ
but i have try change the ept i think this is not orginal info sn on my interface :4637
when i,m back home i tell ok ? thanks
kospoz
i mean new winxp install
You have microsoft c++2005?
