here
checksum calculated
--> MAZDA6_dpf_chck.rar
hi guys,
someone can help me please.
i have a mazda 6 2000cm3 diesel, year 2006 with ecu RF7K, i need fap off please.
all informations about ecu in zip file.
mazda 6 RF7K.zip
here
checksum calculated
Helder Costa (3rd May, 2016)
thanks Kinketotua,
i will try and report.
hi Kinketotua,
first all ok, but when i drive 20 kms i have fault code P0546 and car loose power.
someone can help please
P0546 Exhaust Gas Temperature (EGT) Sensor Circuit High B1S1
check sensor in diagnostic measure.
EGT sensor protect you engine before overheating ! Must be working, so if it's bad.. dpf not removed or some mess in file
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
Helder Costa (5th May, 2016)
did you solved? if not, I can disable the fault code if you want
Removing code not restore power, and... engine will be unprotected before overheating if sensor is broken !
BEWARE
hi,
i try to change sensor for a new one but error still present when car drive some kms.
someone have a good dpf off file for this car?
i can do good dpf.
Solved,
thanks to all
how you solved?
i put another file and everything is ok.
thanks to all.
