Results 1 to 2 of 2
    DK Veteran loncell's Avatar
    Jun 2008
    Default vusolo2 NAND replacement question
    If you replace the TSOP-48 in a vusolo2 does it have to be the identical TSOP48 make/model No or can you use different type ?
    Junior Member suttsy's Avatar
    Jun 2013
    on Hotbird
    If your referring to the flash I/C chip, then yes.
    However, if your box is a clone then you'll be doing well to get that chip, as it appears they are no longer available from the supplier.
