Results 1 to 5 of 5
    Apr 2016
    Default Volvo 2.4D D5 DPF OFF
    Got this car and disable the DPF by single switch like i normally do but it?s throwing 2 permanent errors on VIDA.
    One is the dpf pressure sensor and the code is ECM- 2A00
    The other is CEM 1F100 but i think its normal as the car was modified, don?t think it?s possible to disable it?
    Needing a DPF and pressure sensor off combo solution.
    Thanks in advance.
    BR,
    Michael
    Dec 2015
    PL
    maybe it help you...
    DTC 2A00 OFF
    WinOLS (Volvo (Version 1) - 512763).rar
  3. The Following User Says Thank You to mateusz1611 For This Useful Post:
    SpecZ (6th May, 2016)
    Apr 2016
    Thanks.
    As the car needs some work to program by obd is there anyone that can confirm that just the 2A00 off DTC will work?
    Apr 2016
    Not working.
    Someone can provide me a dpf and pressure sensor off tested file?
    Thanks in advance.
    BR,
    Michael
    Apr 2016
    Nodoby can sort me out?
