Results 1 to 12 of 12
    Jan 2016
    Default I/O Link & distribution
    Is there a limit to how many magic eyes I can run from this?
    I have Sky HD box with I/O link connected, the I/O link is powered from a 240v supply
    I also have an openbox which has an RF modulator connected, the RF modulator is also powered from a 240v feed, both the RF modulator and the I/O Link are daisy chained together and sent upto the loft where there is a 5 way splitter with power pass (This is not powered) and is distributed to 3 TV's atm and works perfectly
    I want to add 2 more TV's to this set up, might I add I have magic eyes on all the TVs so I can change channels still on both the sky and openbox
    Is there a limit to how many magic eyes I can run? reason i ask is because I installed my 4th tv over the weekend and when i connected the magic eye it did not power up, i tried it on a separate tv that is already working and was fine, i can still watch both the boxes but am unable to change the channel because i do not seem to be getting any voltage down the coax
    Help please
    Nov 2015
    Are you running boxes of ***** ??
    Jan 2016
    boxes of what?
    maca's Avatar
    Feb 2009
    liverpool
    Jan 2016
    Quote Originally Posted by maca View Post
    digicon's Avatar
    Jul 2009
    You would be better using a Powered Power pass amplifier in the loft
  7. The Following 2 Users Say Thank You to digicon For This Useful Post:
    Johnner (6th May, 2016), PJD (19th May, 2016)
  8. #7
    Jan 2016
    Quote Originally Posted by digicon View Post
    To do this, would I need to disconnect the 240v supply's for both the I/O link and RF Modulator? or would it still be fine to leave connected?
  9. #8
    digicon's Avatar
    Jul 2009
    You can take the PSU off the I/O link as a powered Amp with DC pass will take care of distributing the signal and powering the magic eyes, your RF modulator for the openbox will still need its power
  10. The Following User Says Thank You to digicon For This Useful Post:
  11. #9
    Jan 2016
    Okay thanks
    Is this the kind of thing that will be needed?
    http://www.ebay.co.uk/itm/1217764436...%3AMEBIDX%3AIT
  12. #10
    digicon's Avatar
    Jul 2009
    Yes! thats the type your looking for
  13. #11
    Jan 2016
    http://www.ebay.co.uk/itm/LABGEAR-12...8AAOxyUylTTCw0
    I think I will go for this instead, the other unit has F converters on in which means an extra joint, this comes with F connectors as standard, also the rest of my set-up has Labgear so is nice to keep it all the same I think
    Do you think this would be okay?
  14. #12
    Jan 2016
    I ordered the second Amplifier in the end, works a treat.
    Took a feed from the light switch and into a fused spur, fitted a 3a fuse, then fitted the 2 gang socket which powers the Masthead and Amplifier.
    Cables are routed as follows....
    Masthead to 12V feed in > Freeview out to Sky Box
    I/O Link and RF modulator daisy chained together and feed up to loft and into UHF in
    Then a feed down to each room with a tv which carries its own 9v feed to power the Magic eye, have Sky, Second Satelite box and Freeview on all TV's and the ability to control in each room
    I tried to disconnect the power feed for the I/O link but lost the picture so just switched off the I/O link power supply from the actual secret menu inside the Sky box, this didnt seem to affect the picture.
    All in all a good job, so thanks for your help I am very happy with it.
