here you go mate
pass in PMWinOLS (Lexus IS220d (+43hp +90nm +DPF OFF) - 89663-53590-).rar
here you go mate
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
Thanks for fast respond with help...
Respect.
HI, today tried to write your moded file , but no succes. When opening moded file I got error BAD FIRMWARE IMMAGE STRUCTURE. with oryg no errors.
Same if I trying to change 1 byte in oryg file. I got same error.
Never had issues before with toyota ecu flasher, make sure you select proper processor and erase before writing
Problem that I have problem to write oryg file.
today tried first time to write , but no success. Tried bdm and obd, but got same error in picture. Read ok tried 2 lexus is220d but cant write.
Do I need to erase flash first ???
Yes mate, need to erase flash before writing
darius89 (18th October, 2016)
Before write new file, you should erase
Sent from my C5502 using Tapatalk
I have problem with is220 can some one check dpf off file its removed ok . Car go to 1200 rpm when idle .
NO PASS
