Results 1 to 3 of 3
Thread: Just question
    Oct 2013
    Sudan
    Default Just question
    Hello all,
    I have a Denso Hilux ECU 2009 - and car has DTC code : P0093 Fuel System Large Leak Detected, not all the time this code will come,,,but when it come, the car will be in safe mode and rpm will be limit to 2000 unless you switch off and start engine again
    if this code has been disable/remove from ECU map file ,,, what happen then,,will i have "safe mode" without code present ?
    thanks for all
    Andrei2015's Avatar
    Oct 2015
    If you remove dtc, limp mode will remain
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  3. The Following User Says Thank You to Andrei2015 For This Useful Post:
    yem22 (8th May, 2016)
    Oct 2013
    Sudan
    Thanks for info
