    DK Veteran 70max's Avatar
    May 2012
    Default Please info read and write help Gp.1_3 HP 75 EVO 8F3
    Greetings to all friends of DK,
    With my V54 Clone
    I read OBD this file G.P 1_3 mjt ECU 75 8F3 for dpf off,
    I wanted to ask you more experienced if the file read is correct and if I can write by OBD the modified file.
    if someone has made up in J-tag of this ECU can send it to me?
    Thanks to all of your answers
    Best Regards Max
    carmageddon's Avatar
    Italy
    you can not read-write obd/jtag 8f3 with clone fg, only 8f2.
    this ecu is 8f2 (as you can see at address 1d0025-1d0035-1d0048-1d005a).
    i think you can not write obd with v54, maybe jtag yes....maybe
  3. The Following User Says Thank You to carmageddon For This Useful Post:
    70max (8th May, 2016)
    May 2012
    Kess V2 4,036 or 6,070 KTag Clone
    I can write this ecu?
    Italy
    if 8f are listed i think yes
    May 2012
    Quote Originally Posted by carmageddon View Post
    Ok Thanks Carma,
    Let's see how I can do.
    Best regards
    May 2012
    Carma,
    You're right Ecu 8F2
    You have Backup in J-Tag this Ecu?
