Results 1 to 12 of 12
    Nov 2008
    Default Eurovox MaxV No Signal
    This morning, some channels were displaying "No Signal" when selected.
    After investigating further, i noticed the following CH NUM's signal quality is very low (RED bar)-
    0003 - 290 000MHz
    0018 - 547 000MHz
    0023 - 594 000MHz
    0031 - 698 000MHz
    0036 - 738 000MHz
    0037 - 746 000MHz
    It's been working fine for 1 year or so and i did the latest firmware update a few months ago, but I am fairly new to this, Do you think the low signal quality is the cause of the problem and if so, how can i fix it?
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    do the rest of your channel's work ok, have you tried a channel update the ones with a low signal may have moved freq's
    Nov 2008
    Yes, the other channels work fine and tried updating as well
    If the freq. has changed for the one's that are low signal, how can i fix this?
    Feb 2009
    glasgow
    Hi m8 you would have found them when updating if the rest if the channels work then you may need a booster press menu ,ok , config , tv settings and see if there is one there and if you are using a splitter remove it and use a direct feed
    Nov 2008
    Hi Chic
    Don't appear to have the booster option.
    i think there is a splitter outside, (Will check) but i don't understand why the problem occured the other day after working fine for a year or so?
    Feb 2009
    glasgow
    Hi m8 vm could have moved your feed in the green box in the street i think the higher up in the box the stronger the signal or it may be the lower in the box anyway thay might have moved it have you checked that all your connections are tight
    Nov 2008
    Checking now
    Nov 2008
    All connections appear to be tight
    The box on the wall inside has a TV/FM splitter with only the TV socket used.
    The box outside on the wall has a 3db,7db splitter.
    3db cable goes to the box inside
    7db cable goes to internet router
    What should i try next?
    I'm sure i had the booster option before - did the recent firmware update remove this option?
    thanks again
    Feb 2009
    glasgow
    can you try the feed from your broadband to your box to see if it makes a diffrence
    Nov 2008
    Chic - tried that but it made no difference (some real big spiders in the box outside...)
    it's confuding me why it's only affecting certain frequencies (listed above), and not all of them??
    Is there any way i can delete the affected CH NUM's (0023, 0031 etc) and force it to re-detect them?
    Feb 2009
    glasgow
    Quote Originally Posted by horus View Post
    you could delete them one at a time then update channels but you have tried that , i would do a factory reset this will delete ALL your channels then do a power scan on the sy rate for your area.
    Nov 2008
    Quote Originally Posted by chic. View Post
    The above suggestion worked (delete and power scan) - Thanks
    As you send in your original reply, i think VM have moved some of the frequencies.
