Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
  1. #31
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by Faraday View Post
    as far as I remember EFFi never been for free
    Search for crack...
  2. #32
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by super jumbe View Post
    Search for crack...
    I don't need it since I'm legal user of EFFi
  3. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    obdsystems (15th December, 2017), Recoder (16th December, 2017)
  4. #33
    jodge's Avatar
    Mar 2017
    Lads why spend money on tools? For most Fiat cars you need to spend more then just pulling pincode!!!
    You also need to precode the transponder the cheapest way I have found is bsi out of car read chip and get pincode with Eefi then precode the transponder all done with free Eefi software why spend money when all this will be done in 20min…
    it just the TP. If you need remote functions you will need miraclone/tmpro/avdi... But IO terminal give you correct remote config data and you can write it with any HITAG2 prommer
  5. #34
    Dec 2017
    i use AVDI works weary good from 2005-2012 is difrent procedure reed eeprom by obd after put to editor after 2012 is automatic only chose reed pin
  6. The Following User Says Thank You to mlodywafel For This Useful Post:
  7. #35
    Mar 2013
    Patagonia Argentina
    zedfull works great with sudamerican fiats too, precode and program all by obd2. works great in inmo in dash model. in body inmo model you need to unplug the +30 (show in pictures). for inmobox need to read motorolla (better use upa and effi)
  8. #36
    didi_du_93000's Avatar
    France Paris
    AVDI will not do more than SMOK and IO
    BUT 3 time more epensive than SMOK and IO!!!
    About IO, I think it's beter, give more information for remote prepare, and also beter list
    AND FREE UPDATE!!
  9. #37
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by didi_du_93000 View Post
    AND FREE UPDATE!!
    according the support pages:
    IO terminal fiat BSI support list
    Magneti Marelli with Freescale MCU 3K91D,1k79X (R/W EEPROM SHOW PIN) .
    Magneti Marelli with NEC MCU 70F3237,70F3378 (R/W EEPROM SHOW PIN).
    Siemens Continental Freescale MCU 9S12DG128  (R/W EEPROM SHOW PIN).
    SMOK fiat bsi support list
    FT0013 Magneti Marelli Body Fiat NEC70F3227 +95160 Read/Write EEprom , Read Flash , Read PIn Code
    FT0013 Magneti Marelli Body Fiat NEC70F3378 +95160 Read/Write EEprom , Read Flash , Read PIn Code
     FT0013 Magneti Marelli NEC70F3633 +95320 (Read/Write EEprom , Read Flash , Read PIn Code)
    FT0013 Magneti Marelli Body Fiat MCU +95640 Read/Write EEprom , Read Flash , Read PIn Code
    FT0013 Magneti Marelli Body Fiat MC68HC912DG128 Read/Write EEprom , Read PIn Code
    FT0013 Magneti Marelli Body Fiat MC9S12DG256 Read/Write EEprom , Read PIn Code
    FT0013 Siemens Body Fiat MC9S12DB128 Read/Write EEprom , Read/Write Flash ,Read PIn Code
    FT0016 Delphi Body Fiat 70F3237+93c86 Read/Write EEprom, Read Flash
    FT0016 Delphi Body Fiat 70F3379+93c86 Read/Write EEprom, Read Flash
    FT0016 Delphi Body Fiat 70F3632+93c86 Read/Write EEprom, Read Flash
    FT0016 Delphi Body Fiat 70F3633 (without externa eeprom) Read EEprom
    FT0016 Ford KA Body 70F3379+93c86 Read/Write EEprom, Read Flash
  10. #38
    France Paris
    You forget this from Ioterminal.com
    http://ioterminal.com/?page_id=1081
    Quote Originally Posted by jodge View Post
    Supported DELPHI BSI types
    FIAT DELPHI BSI 70F3237+93C86 CAN . EEPROM 93C86 R/W ,show PIN, show KEY preparartion data. 70F323 FLASH R.
    FIAT DELPHI BSI 70F3379+93C86 CAN . EEPROM 93C86 R/W ,show PIN, show KEY preparartion data. 70F3379 FLASH R.
    FIAT DELPHI BSI 70F3633 CAN . 70F3633 data flash read ,show PIN, show KEY preparartion data.
    FORD DELPHI BSI 70F3379+93C86 CAN . EEPROM 93C86 R/W ,show PIN, show KEY preparartion data. 70F3379 FLASH R.
    With Tapatalk
  11. The Following 2 Users Say Thank You to didi_du_93000 For This Useful Post:
    jodge (15th December, 2017), rob h (14th December, 2017)
  12. #39
    szengen's Avatar
    Jan 2017
    read xprog program, tmpro2,advanced code evo, obd ad100pro
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  13. #40
    szengen's Avatar
    Jan 2017
    can be changed, final good ad advanced, tmpro2
  14. #41
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    AVDI igreat for fiat - used TMPro also but newer cars have no eeprom
    AD100 missing remote pre-code on vans ducato etc
    I am a FUD
  15. The Following User Says Thank You to obdsystems For This Useful Post:
    euroscan1 (17th December, 2017)
  16. #42
    castin's Avatar
    Oct 2015
    I/o terminal work without working key, if you dont hawe working key, smok tool don't read body.
  17. The Following User Says Thank You to castin For This Useful Post:
    Weasel3 (15th March, 2018)
  18. #43
    France Paris
    but becarfull!!!!
    I have read on an thread. On some new Fiat cars if you open car without using key/lishi/turbodecoder/pick lock you will active alarm and the BCM will be locked. You MUST change it if it's locked.
    If any one can confirm.
    Regards,
  19. #44
    Mar 2018
    Truecode. All that needs to be said.
  20. #45
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by ibritstone View Post
    nope
    either truecode (FATC1) or avdi unable to read all BSI w/o pincode (trucode Marelli and avdi Delphi)
    Ioterminal don't need pincode or working key. It takes 15 min to brute force the Freescale (Mask 3K91D or 1k79X) MCU.
