Results 1 to 7 of 7
    PSAcars's Avatar
    Oct 2015
    HOME
    Default Help please with CDC2 Blaupunkt
    Hi to all please help with CDC2 Blaupunkt. A friend of mine disconnected the battery on opel astra and now cd changer locked. I have original upa but read a lot of posts where trying to read, eeprom is erased. I found this in datasheet of motorola mc68hc05x32: SEC ? Secure bitThis bit allows the EPROM and EEPROM1 to be secured from external access. When this bit is inthe erased state (set), the EPROM and EEPROM1 content is not secured and the device may beused in non user mode. When the SEC bit is programmed to ?zero?, the EPROM and EEPROM1content is secured by prohibiting entry to the non user mode. To deactivate the secure bit, theEPROM has to be erased by exposure to a high density ultraviolet light, and the device has to beentered into the EPROM erase verification mode with PD1 set. When the SEC bit is changed, itsnew value will have no effect until the next power-on or external reset. Please help with solution for code. I can not find code generator.
    Jul 2013
    try this file
    cdc2.rar
    PSAcars's Avatar
    Oct 2015
    HOME
    I dont need a file. I need to know if I read motorola will I kill it or no?
    sonices's Avatar
    Jul 2010
    You wont kill it if you do it right, but also you can post serial and part number and i will give you code
  5. The Following User Says Thank You to sonices For This Useful Post:
    RadioChiP (11th May, 2016)
  6. #5
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello again this is the cd-changer.
  7. #6
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by PSAcars View Post
    Hello,
    Your code is .. 7306
    http://codedradio.info/?i=bn&st=+90+569+379
  8. The Following 4 Users Say Thank You to Albert G For This Useful Post:
    masterskay62 (12th May, 2016), PSAcars (12th May, 2016), REZON (12th May, 2016), smoggy (12th May, 2016)
  9. #7
    PSAcars's Avatar
    Oct 2015
    HOME
    It is working. Thank you. What calc did you use to get serial?
