Results 1 to 4 of 4
    Mar 2008
    Default Multiboot IPBOX 9000HD By Damir
    FOR IPBOX 9000HD!
    In the folder that contains the copy of this program, copy
    Enigma 2 release (eg, "release_041_cuberevo.tar.gz") or
    any another that has an extension "*.tar.gz".
    The program served to fill the original environment and the user environment.
    Preparing the USB stick, formatted it and installed it on enigmu2.
    Be patient and follow the instructions on the program.
    Press number button on RCU which you want booting mode.
    Multi-booting support as below.
    1) boot from cdkroot
    2) boot from USB with hdd
    3) original images
    4) boot from release
    5) boot from USB without hdd
    6) boot from SATA hdd
    7) boot from flash
    This is a beta release.
    Now you can run "DD_enigma2_IPBOX.exe",
    it is not necessary more run "start.bat"
    Best regards
    DDamir
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Sep 2009
    Default borislav111
    thanks very mach great programs
    Member grizzlyt's Avatar
    Oct 2008
    Default Multiboot IPBOX vers.0.55 By Damir
    This is the newest version.
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  4. The Following User Says Thank You to grizzlyt For This Useful Post:
    Dec 2010
    Default Thanks!
    Useful info, thank you !
    Best regards BBBB
