checksum is ok
checksum is ok
YOUR MOD IS VERY BAD. DO NOT PUT IT INTO THE CAR!!!!!
This dump is from a correct ECU. With this file car work perfectly. I want to clone the ECU but I can't write file on ECU that I want to clone. I have tl866a programmer
try another programmer
I have tried but no success. I have galleto v54 and I try in boot mode and via OBD but nothing, this ECU not communicate with programmer, so I accept to remove the flash (29f400bt) to re-write with tl866 but I can't write, this flash is new I buy the new because I mind the ecu flas is damaged. I don't know why tl866 can programm this flash. I can read but no write
evisdaci (16th May, 2016)
Yes, i have erase before and writing. I don't know why. When i try an example dump file with a small size (just exaple, not correct dump) i can be write, but when i try a correct file like file that i have post i cant mate
Try with MPPS in recovery mode
I haven't MPPS my friend
thayer201, i have try what you suggest me but nothing, follow i attach the photo of problem. Have you any idea ?
It's the same situation mate.
