    DK Veteran chiptorque's Avatar
    Nov 2010
    Default I need EGR OFF ECU 7L0907401N
    Hello fellow EGR OFF need in this ECU and if I have to disconnect or leave connected.
    Thank you.
    Nov 2010
    please.... Any help?
    Sep 2010
    Quote Originally Posted by chiptorque View Post
    try & report
    Leave connected
    pass pm.
    Nov 2010
    thanks, It is similar to VOLTA. and it does not work well, leaving other failures, but if you are sure it works I test
    Sep 2010
    Hmm similar, yes, but not totaly same as volta. Volta make mistake.
    Don't know if you have electrical problem with egr? In this case you must do dtc off too.
    Please write scanned dtc's related to egr.
    Nov 2010
    thanks not work, I get the same error, then they sent them.
