Results 1 to 5 of 5
    Aug 2010
    Default toyota avensis 2.2 from 2008
    after removing the fap file from toyota avensis 2008 2.2 cc with galletto original and swiftec ,the car start ok at know dont do regeneartions but the car go to slowly and take much time to arrived 180 km/h in swiftec say disconect 5 cylinder but where goes this sensor ? where i can find it ? only can see the 3 conectors on fap place is one off them ? thankyou
    Andrei2015's Avatar
    Oct 2015
    Need to disconnect the 5th injector not sensor
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    mislav88's Avatar
    Mar 2011
    disconnect 5th injector which injects fuel in exhaust system, trace fuel lines and you will find it.
    Aug 2010
    ok thankyou i will try ,but for sure that is the problem for car dont have power no?
    Andrei2015's Avatar
    Oct 2015
    what about before? I know that this ecu's do regenerations and see a lot of smoke, I never encountered a limp mode on them and I am doing them from few years(started with emulators)
