Hi tuners,
I'm looking into tuning my car and was expecting to be able to flash adapted data using the BMW standard tools WinKFP program. I am able to flash .0da files supplied by BMW without issue, but when I flash a changed file I get "security access denied" in WinKFP. After this I'm still able to flash back the original file, again without issue.
The changed file has been checksum corrected with 'checksum corrector' tool as well as WinOLS, both delivering the same checksum at the end of the file, so I'm guessing that's not the issue.
Procedure followed:
- Generate a bin file based on the original .0da file, using my own written python code (DDE509/U7812338.0da)
- Edit the bin file (in this test, changed the hysteresis map for the EGR actuation)
- Fix the checksums
- Generate a 0da file based on the changed bin file, again using my own written python code
- Fix the 0da file checksum using NCSDummy
- write to the car using WinKFP
U7812338.0da.zip
U7812338.0da.egroff2.zip
WinOLS EGR off2.zip
7812338.zip
Is anyone able to shed some light on what I might be doing wrong..?
Daniel
