Results 1 to 11 of 11
    Default Harley Davidson softail dash
    Gotvthid dash here has a eeprom Atmel 142 anybody can tell me what eeprom is cheers
    Sent from my SM-G935F using Tapatalk
    clusters's Avatar
    Mar 2015
    Canada
    I believe it's a 93C46 in that one, but not sure.
    Dec 2010
    The Sportster i did had 93C46, but please check if it is not 24C01. If the ground is on pin4 then it might be 24. If the ground is on pin 5 then it is 93.
    It was actually a 95010 eeprom
    May 2011
    hey javyb how did u get the chrome surround and cover off
    ive got the same speedo here and trying to remove to chrome ring but dont want to wreck it
    clusters's Avatar
    Mar 2015
    Canada
    You have to pry it back gently, working your way around it till it will come off. There is no way to do it so you can't tell.
    May 2011
    hi thanks clusters
    this seedo has been changed and has 9000 kms on it and i want to make it 24000
    so ill see if he wants me to come over and just put a signal generator on the speedo sensor wires and get it up that way instead of damaging the speedo
    clusters's Avatar
    Mar 2015
    Canada
    Might be the best way, but it will take around 70 hours.
    You can only feed so fast a signal to them before error.
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Its 24c01 eeprom .....................
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
    May 2011
    ok thnaks ill ask cusotmer what he wants to do
    May 2011
    hi guys i pulled my dash apart and its slightly different to pic above
    does anyoen know what chip i need to read
    there is a small 8 pin chip with mzc 3339 on it
    Attachment 431459
