    DK Veteran chiptorque's Avatar
    Nov 2010
    Default Flash File ECU 0281001761 MAN TGA 360
    hello friends, yesterday there was a problem diagnosis recording by this truck, I had read and was recorded well but will not start. Flash Original seek, but 512 Kb.
    this the read KESS V2.
    Nov 2010
    Please, Now the truck will not start or loading the file directly into the ECU, out breakdown of heaters. I need another to try.
    Sep 2014
    Simply use search
  4. The Following User Says Thank You to hcwc For This Useful Post:
    gameiruz (10th July, 2017)
    Jul 2012
    Default man sw 761
    Quote Originally Posted by chiptorque View Post
    I do not think that the problem is flash .. your reading file seems ok ..
    attached a file 761sw you could try to write this ...
    I think that the cause is other
    ms6.3 ? or ms6.2?
    Jul 2012
    Quote Originally Posted by hcwc View Post
    Simply use search
    your file has different dimensions ..
    I sent golds file size 512kb
    Nov 2010
    Thanks to the 2 companions. the ECU is MS 6.1, if not a Flash problem that could have happened?
    The file is also a 410 and I've tried doing the same with everyone.
