Results 1 to 9 of 9
    Fallen's Avatar
    Default Cross reference BMW part numbers to ECU type
    Is there any program that will cross reference BMW part numbers to the actual ECU used?
    For example, I had an X6 the other day and I wanted to know what DME was in it.
    I got a BMW part number of 8573235
    Google search did not find anything to identify it as MSV70/80/ DME7/8
    Cheers
    Moderator
    PremierD's Avatar
    Jun 2009
    http://www.realoem.com/bmw/enUS/partxref?q=8573235
    May be sh1t though
    Apon reflection .. it is
  3. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    Fallen (21st May, 2016), MV auto (23rd May, 2016), smokey08 (21st May, 2016), Voltish (7th April, 2020)
    try on realoem with the following part number 13618573235
    EDIT: beaten by PremierD
  5. The Following User Says Thank You to u.s For This Useful Post:
  6. #4
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by u.s View Post
    you mean the one that I posted mate .. http://www.realoem.com/bmw/enUS/partxref?q=8573235
  7. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    Fallen (21st May, 2016), u.s (20th May, 2016)
  8. #5
    yup, and edited before you posted this...haha
  9. The Following 2 Users Say Thank You to u.s For This Useful Post:
    Fallen (21st May, 2016), PremierD (20th May, 2016)
  10. #6
    Fallen's Avatar
    I would kill for a decent x-reference program.
    So many times I get the same problem.
    Tool developers, if your reading this, why not put the ECU ID that we all know?
  11. #7
    Nov 2010
    For E60/E90 look for: SA-Option Helper / FindECU small software. It requires SPDated and it will give you everything you need.
  12. The Following User Says Thank You to znakedwrx For This Useful Post:
  13. #8
    Fallen's Avatar
    Quote Originally Posted by znakedwrx View Post
    I'm not following you here, SPDated is a program?
    Google turns up nothing.
  14. #9
    smokey08's Avatar
    Essex, UK
    For the Bosch units this is fantastic. Use realoem to lookup the long part number then on the bosch site click external number and write the long part number in.
    Ecu from picture in first post is: EDC 17CP45-2.32. Bosch number 0281019628
  15. The Following 7 Users Say Thank You to smokey08 For This Useful Post:
    alclot (14th December, 2017), bram380 (22nd May, 2016), darkshiningg (27th May, 2016), Fallen (22nd May, 2016), igorr (22nd May, 2016), MV auto (23rd May, 2016), PremierD (21st May, 2016)
