v8s problem
  • hatchet123
    • Mar 2016
    • 9
    v8s problem
    hi,a mate as had an openbox v8s for over a year now without any problems,he installd a new line a few weeks ago,again no issues until yesterday,all pay channels,except documentaries and sports are clearing ,so the line is ok ,so could this be a firmware problem?any suggestions,thanks .
  • gary229
    • 265
    If your mate has been updating channel lists using a usb then its best for him to try this menu> factory settings> ok on yes> IMPORTANT now press blue. This will erase all channel list data, reload Cwaites list and that should sort it.
    I will add though I know of two folk recently that have the same issue and funnily enough the documentaries wouldn't clear, strange.
    • hatchet123
      • Mar 2016
      • 9
      thanks for your reply, will try later
      • hatchet123
        • Mar 2016
        • 9
        tried what you suggested but no joy,its strange, gold wont clear but gold+1 does,sly sports wont clear but bt sports does,firmware onthe box is :-3511hd_07-12_2014 0923,do you thimk this needs updating,thanks
        • P&D
          • May 2010
          • 2686
          Just upgrade the firmware & see you won't know till you try.........
          • idontknow
            • 9
            I've had this issue for ages, tried nearly everything, including putting older firmware, but the box never seems to erase all the way back to factory settings?
            • staden321
              • Nov 2015
              • 73
              Some .................................................. ..
              • PremierD
                TAMINATOR
                • Jun 2009
                • 13137
                Some planks .. need to read these ..
                • staden321
                  • Nov 2015
                  • 73
                  I'll rephrase some lines only work on selected channels it's not your firmware. Get another line
                  • staden321
                    • Nov 2015
                    • 73
                    Sorry for being a plank I was only trying to help will be more careful in future
                    • paul93
                      • 50
                      When i upgrade the above software for V8S with USB it says Software OEM ID Mismatch please help
                      • P&D
                        • May 2010
                        • 2686
                        The link above is the old software try this link for the new up to date software...http://www.openbox.cm/index.php?c=article&a=type&tid=2
                        • nmmalik8
                          • Dec 2013
                          most paid channel not working any more on satellite boxes, v8s etc. try web tv. but you need valid subscription
