There is not "hot start problem" in the file.
How the engine start if you disconnect the Temp. sensor when the engine is hot?
Yes U right engine start after disconnect Temp sensor (engine hot)
With the temp. sensor connected car does not start or starts worse , when dissconect sensor starts well ?
wrong injection timing
To wronapl ..Yes exactly
To igendek ..ok how can I adjust injection timing ?
First, check injection timing using VCDS.
Mot type is ACV 100PS. You have 2 timing belts. Check both and set timing pump at 0.3-0,4mm BTDC
t77 (26th May, 2016)
Did you confirmed starter and battery??
Most of problems " hot start" i have seen are low rpm on start.
No I none checked starter and battery ..but why after disconnect Temp sensor , during crank engine (hot) starts in the moment
OMG...!
You want to tell us, that 35 mg IQ is not enough to start the engine ???
Make some diag - IQ, SOI at idle, warm engine...
Post here the readings.
.Too slowly turns the starter , check the current consumption and state battery.Hot engine dosage starts from the specific rotation rpm.Cold dosage starts from 0 rpm .
Bobolin4o look my post #3 (after disconnect Temp sensor engine hot starts in 1 second no more crank long)
