    Default w204 delphi crd 3.10
    hello.after readind this ecu by obd i make a big mistake and write a wrong file from other w204.now car dont work and cant write the correct file by obd.can i write it on bentch?its tricore 1797.whitch tool to use and can someone provide pinout and boot pin?thanks
    nizarben's Avatar
    Dec 2013
    your reading done with what?
    nizarben's Avatar
    Dec 2013
    I use kess v2 for CRD3 no problem
    Andrei2015's Avatar
    Oct 2015
    Default connection
    Compare with this pleaseENU_L_DELPHI_MEB.rar
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    i read with kess but now cant read it again.comparing to mine its the same as crd 3.40.gonna try and see if it reads
    ktag must be firmware 6?
