Results 1 to 1 of 1
    Aug 2010
    Default Problem activating cruise control Audi A6 4F
    I have a problem with activation of cruise control on an Audi A6 2005 3.0TDI BMK automatic.
    I installed a cruise controll switch code 4E0953521B. Make 1 wire connection from 16-pin connector behind steering column switch trim to 17-pin connector left in plenum chamber. Make the coding to chanel 16 Steering wheel 4F0953549B. But every time I enter in Engine section on Coding II the 11463(or 16167 for deactivation) code I get message " Error 22: Condition not correct or request sequence error "
    I have only one error code on Address 05: Acc/Start Auth - error 00166 - 010 - Open or Short to What is the problem?
    If anyone can help?
    Can I do the coding directly in eeprom from ECM? (here is the file)
