Results 1 to 4 of 4
    Default LT46 Remove speed limiter MSA15
    I try to remove speed limiter around 56 mph on a VW LT 46 2.5 TDI 102 with 0281001889 074906021 AP ecu but without success !
    Ecu is an old MSA15 with one plug, 2x27C010 inside and 1xeeprom.
    I read the B58253 eeprom (24C02), here is original dump.
    Somebody have a solution for this ecu ?
    Thanks for help
    BR
    Babos's Avatar
    Mar 2012
    Hi try that dumps
    Thanks, car is far away from me so it will be hard to test...
    Noboby have a tested solution ?
    Nobody have solution ?
    A tuner tell me that i have to change ecu, no way to increase speed limit ??? Right ?
