Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Default Opel Corsa C - Need PIN from display and unregister radio
    Hello guys,
    Can anyone please provide PIN from Borg display and unregister my radio?
    Regards,
    Sima
    Nov 2015
    Poland
    Bad dumps, friend
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Hi, you are right, I think so dump is wrong too.
    Scripts for Multi-PROG
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
    Aug 2013
    Serbia,Belgrade
    Sorry,here is correct radio dump.
    Display inc. in a few mins for code.
    Nov 2015
    Poland
    Blaupunkt CD30 / CD30 MP3 M95640 module loaded.
    File size check OK! Size is 0x2000 bytes!
    File ID check 1 OK!
    Radio Serial: GM003049413116
    Alpha code: FH
    Model: CD 30 MP3
    Security code is: 9230
    here is security code, if you have opcom / tech2 you can unregister this radio
  6. The Following User Says Thank You to stachu22 For This Useful Post:
    simaservis1108 (30th May, 2016)
  7. #6
    Aug 2013
    Serbia,Belgrade
    And here is display dump,correct.
  8. #7
    morfej's Avatar
    Dec 2008
    Radio has code: 9230
  9. #8
    Nov 2015
    Poland
    Display dump still looks not correct for me..
  10. #9
    Aug 2013
    Serbia,Belgrade
    And in X8 format.
  11. #10
    morfej's Avatar
    Dec 2008
    Diplay is now ok : code 8533
  12. #11
    Nov 2015
    Poland
    display PIN: 8533
  13. #12
    Aug 2013
    Serbia,Belgrade
    Could someone unregister my CD30 dump?OpCOm not working...
  14. #13
    dragon100's Avatar
    Jan 2012
    Which version opcom ?
    Best regards.
    Dragon
  15. #14
    Aug 2013
    Serbia,Belgrade
    V1.39 and V1.45 - both show success,but still not unregistered.
  16. #15
    dragon100's Avatar
    Jan 2012
    You should try on 1.59 if your opcom board with PIC .
    Best regards.
    Dragon
