Which ecu ?
Which ecu ?
VAG
at the beginning of EDC16
Like have said Mr.Babos you can try first with Visteon,not many dtc in file !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
find DTC is not a problem but where the switch
[Quote = RJ22; 2.779.716] Ciao
come trovare l'errore interruttore saluti [/ quote]
vag EDC16
interruttore dtc = indirizzo DTC - indirizzo del blocco di partenza DTC / 8 + inizio del blocco switch
Sisco,could you keep it to English please ? Noone understands what you're on about !
I'm sorry for my English, I wanted to say this:
to find switch for DTC to be reset must first find the dtc in hex 16bit (p0404 try to find 0404 no letter p) then find the block start address dtc then find the start switch block address after doing this
dtc-start dtc / 8 + start switches
when evete found the switch address to reset do it in 8-bit
sorry again for the English but I use google
Jacob6969 (23rd March, 2020)
as for the attached file edc16u34
p1495 = 1cea36
start dtc = 1ce6ac
start switch = 1cf2ac
operation:
1cea36 - 1ce6ac = 38a
38a / 8 = 71
71 + 1cf2ac = 1cf31d
1cf31d is switch off for dtc p1495
Attachment 379263
maybe help anyone for delete dtc from edc16, edc17.
exsampe for
p1495 = 1cea36
start dtc = 1ce6ac
Attachment 379349
