Results 1 to 14 of 14
    May 2016
    Amsterdam
    Default How to clear crash data from Volvo V50 Airbag ?
    I want to fix my airbag control unit. And I took a picture of it. I would like to know which chip is the eeprom microchip on the airbag control unit? Please, can you help me to erase crash data?
    LT & ES
    Google it
    Entered serial number: 30773786
    Brand: Volvo
    Model: V50
    Manufacturer: Temic
    Year: 0
    Memory type: 9S12DT128 (3L40K)
    Read processor with carprog for ex. and post here. Someone can help.
    May 2016
    Amsterdam
    Quote Originally Posted by olegario View Post
    Google it
    Brand: Volvo
    Model: V50
    Manufacturer: Temic
    Year: 0
    Thanks for your reply. I have searched on google but I could not find anything.(Maybe I am searching in wrong websites) I took some pictures of microchips There are 4 different model microchips with 8 legs on the airbag control unit. Which one is the correct eeprom I don't know. Please can you help me? Thanks
    12C508A _118-0809-62A.jpg4948_AR_W833C.jpg33063_PBMGA.jpgTJA1050_NXP_E2 13_n6810.jpg
    May 2016
    Amsterdam
    microchips and their locations on the airbag control unit
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Look at right upper corner bigger mcu ..."Read processor with carprog for example and post here. Someone can help."
    Scripts for Multi-PROG
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
    Katana1156 (1st June, 2016)
    May 2016
    Amsterdam
    Quote Originally Posted by dragon100 View Post
    Last week I order carprog when I receive it, I will try to read the processor. I hope, I can be successful. It will be first time for me. After I receive my carprog I will come back with my questions Thanks
    dragon100's Avatar
    Jan 2012
    Ok mate, no problem.
    Best regards.
    Dragon
  9. The Following User Says Thank You to dragon100 For This Useful Post:
  10. #8
    May 2016
    Amsterdam
    Hi again
    Finally, Today I have recived my CARPROG. ThenI have connected to my computer to read the airbag chip. Seems like I have found the chip 9S12DT128(3L40K) and read it. Please, can you tell me what is next step to fix the airbag controller unit? Also how can I upload a .bin file to the website?CarProg Full.JPGData.jpgIMG_0863.JPG
  11. #9
    dragon100's Avatar
    Jan 2012
    Post here, and "Go Advanced" then Manage Attachments then Add Files then choice file then Upload and press Done and Submit Reply.
    Best regards.
    Dragon
  12. The Following User Says Thank You to dragon100 For This Useful Post:
    Katana1156 (13th June, 2016)
  13. #10
    May 2016
    Amsterdam
    I have uploaded the .bin file . Thanks
  14. #11
    dragon100's Avatar
    Jan 2012
    Try and report.
    Best regards.
    Dragon
  15. The Following User Says Thank You to dragon100 For This Useful Post:
    Katana1156 (14th June, 2016)
  16. #12
    May 2016
    Amsterdam
    Try and report.
    Is there any way to understand airbag controller unit works well or not without installing the car? I have flashed the crashed_cleared file that you have sent to the airbag controller unit. Also, Thank you so much for the cleared file. I have uploaded 3Crashed_Cleared Data.jpgV50 soldering diagram 1.jpgLift Up - Do I need solder back or not.jpg pictures Please can you check that I have done it correctly or not? Lift Up - Do I need solder back or not? Thanks in advance.
  17. #13
    dragon100's Avatar
    Jan 2012
    After clear, solder back.
    Best regards.
    Dragon
  18. #14
    May 2016
    Amsterdam
    I am great. I lost the little part . Do you think can I find it somehow or airbag control unit is a garbage now?
