    Bosna
    Default SEAT IBIZA EDC15 EGR OFF
    Hi members, need help with Seat ibiza 1.9 tdi.There is problem with egr system.
    DTC
    19586-EGR System
    P3130 -Regulation Range Exceeded-Intermittent
    Somebody please remove EGR.
    ECU is Bosch EDC15, Bosch nr. 0 281 012 276, VAG nr. 038 906 019 NL.
    Dump in attach...
    Apr 2016
    Here you go, with and without checksumm correction.
    Pass by PM.
    Br.
    Michael
    Bosna
    Volta solution, somebody confirm it will work?
    Apr 2016
    Quote Originally Posted by mvekaz View Post
    It does work, no DTC deleted just EGR function disable.
  5. The Following User Says Thank You to SpecZ For This Useful Post:
    mvekaz (2nd June, 2016)
    Bosna
    Ok, thank you.
    Will inform about result.
    wbr
    Jun 2012
    so how come you straight away realised : Volta soloution ?
    Curious to how you can see volta over manual , you looking in winols ?
