Have just had a look with hex editor, but it may work. Just try
I have 520d e60 2006 model with dpf problem the car has not power but no limp mode when i removed the exhaust from the turbo the car became fast again.Can someone remove the dpf from the file?I have also a file with same software that is with dpf off but i do not know if it is ok so if you want take a look thanks
CustomCars (4th June, 2016), kospoz (4th June, 2016)
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
morgano (4th June, 2016)
