Results 1 to 8 of 8
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Default VW Crafter EDC16 need ori or chek this file
    VCDS doesn't want to connect , MPPS no ID , Galletto V53 no ID via OBD.
    Car run ok.
    Autocom/Delphi ok connection and diagnostic and no errors.
    I read files via BDM.
    Please someone to chek this files and if possible send me ori file.
    0281013698
    074906032AE
    sw 503922
    2.5 crafter.rar
    mariusica_boy's Avatar
    Your file is tuned an OBD PROTECTION ON.(for this is blocked read OBD)
    U need make update with VAS or reconstruction flash file original.
    I do not have your file same number software for reconstruction.
    Maybe someoane put here ori file with same nr hardware and software.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following User Says Thank You to mariusica_boy For This Useful Post:
    carbon7319 (3rd June, 2016)
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Thanks mariusica_boy , now let's hope that someone hawe ori file.
    dijo's Avatar
    Quote Originally Posted by carbon7319 View Post
    I think this will help...
  6. The Following User Says Thank You to dijo For This Useful Post:
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Thanks dijo but this sw is 381806
  8. #6
    dijo's Avatar
    m8, you can flash your ECU with this file, and than by Odis or similar tool update...
    you can see SW version after flashing...
  9. #7
    Jun 2012
    I don't think it's a problem of obd read protection. With obd read protection you can diag with vcds, and you can id with tool like mpps or galletto.
    I see your flash has cks corrupted. Try to write only flash in bdm, and let your tool to correct checksum.
  10. The Following User Says Thank You to cawadany For This Useful Post:
    carbon7319 (4th June, 2016)
  11. #8
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Result
    Writing file and cheksumm with BDM 100 - car not start , read after that winols say 9 cheksumms incorect
    Writing file and cheksumm BDM with Galletto V53 - car start work ok no comunication , read after that winols say 1 cheksumm incorect.
    Writing file BDM with Galletto V53 and cheksumm with WinOls - car start work ok no comunication , read after that WinOls say cheksumm correct.
    Help Masters .........
