Hi.
Here you have. Not deleted any DTC, you haven't mentioned any of them If you suffer from them just write here.
Pass in PM.
Regards,
Hi.
Pass in PM.
Regards,
pike (6th June, 2016), spiridonas (4th June, 2016)
pike (6th June, 2016), spiridonas (5th June, 2016)
I have again this message : particle filter additive level too low
i can solved that problem
Additive level is stand alone ECU and you should remove it from BSI configuration if you are disabling DPF in ECU......
In PSA engines no add ecu.
PSA INVENTED FAP filter WITH additive, and others install DPF which is system without additive. PSA have BOTH depending on MY, market and emission standard at the time of production... and if he post last 8 of VIN I can give you all factory data for that car
Please can help me anyone ?
Many thanks in advance.
Read post #6
Even additiv function are disable in BSI that message still are ON ! the reason are ECU wich will send the message via CAN BUS !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
1)particle filter additive level too low
2)anti-pollution system faulty
The problem now is the ecu dpf_egr_off file ?
or the bsi ?
try to recode on engine-fap-section with diagbox,the new quantity of aditive...make 2 liters...done...you will be a big liar for this car...
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
The car come back with this fault : anti-pollution system faulty
and car start regeneration again.
Please can anyone make dpf_egf_off ?
You think it is best way for up you ratio?
Car owner come back again and again?
bobolin4o (15th June, 2016), CustomCars (16th June, 2016), DashProg (16th June, 2016), mihaiservice (15th June, 2016), pelot (20th June, 2016)
