Make sure that you have more than 13V, what car is it ? also make sure that you have chosen proper protocol/car or try with another
Better buy although galletto 54, maybe something's wrong with your cheap tool
It's a mercedes ml 270 cdi 2000
Sent from my SM-G900F using Tapatalk
Try with another tool, Error sk 1 is "connection not available" fault.
Galletto 1260 is bad for use chiptuning..
Greetz from Belgium
are the vents starting ?
Actually that old bugger is not so bad for old cars but for this you should take off the flash and use programmer.
Sent from my SM-A510F using Tapatalk
Thanks for your replies, the fans do go flat out!!
Right plugged it in to a kwp2000+ even worse comes up with error timing parameters! Won't even read the ecu! Pulled ecu out of the car and tried to do it on the bench using kwp2000+ and get (no kick found!) Any help welcome ! Also the galletto 1260 came up with a seed key error, no sure if this has something to do with the sk1 error?
Still the engine start after all this?
If yes, do not bother anymore with those ~~~~ty tools...
Regards!
Lol I like your style
Mate, open the ECU and maybe you'll find something like this in it...
Reading through OBD is possible, writing - is not.
When it is apart it does look something like that! But where do I go from there? Lol
I have made up leads to connect onto the pins e.g power, ground and kline!!
