Results 1 to 15 of 16
    Aug 2011
    Default Hyundai Santa Fe EDC16C39 FAP OFF
    I need help. Upstream temp. sensor not working and thats why I have error P1405-CPF permanent regeneration.
    Need fap off.
    Thanks!
    Jun 2013
    EU
    And change sensor?
    Aug 2011
    Then I need change sensor and fap filter. Filter is full, because about 1 year there have been no regeneration. All the time it has been a error in ecu.
    Jul 2011
    hi. pass.pm
  5. The Following User Says Thank You to draganelektricar For This Useful Post:
    tarts1999 (5th June, 2016)
    Aug 2011
    Is this tested manual solution or you use any program(volta, ecusafe)?
    Thanks!
    Aug 2011
    Quote Originally Posted by draganelektricar View Post
    hi. pass.pm
    This solution not work. I drive about 1km and error P2002 Diesel Particulate Filter Efficency. All sensors are connected. Dpf filter is empty.
    I still need help!
    Please!!!
    macako6's Avatar
    Mar 2015
    Which interface you're doing ECU EDC16C39 ?
    Aug 2011
    Quote Originally Posted by macako6 View Post
    I use Galletto 2.
    I still need help. Can anybody help me?!
  10. #9
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    The car is manual or AUTO this is important .
    I can help but need more info .
    If is auto need bdm read .
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  11. The Following 2 Users Say Thank You to overs0ull For This Useful Post:
    macako6 (20th June, 2016), stanislav georgiev (3rd August, 2016)
  12. #10
    Aug 2011
    Gearbox is manual. This file is bdm read(ecu in table).
  13. #11
    Aug 2011
    I found another Santa Fe file read by obd. And there is dpf off switch in 001cbc30. But my file is read by BDM and this is different.
    Please help!
  14. #12
    Aug 2011
    Help, please!
  15. #13
    Aug 2011
    I try to make myself dpf off. Is there only one switch to need change? Or it is more difficulty?
    This is my neighbor's car. I do not earn anything. Just want help him.
  16. #14
    carbon7319's Avatar
    Aug 2011
    Macedonia
    SantaFe.rar
    Try this mods
  17. The Following User Says Thank You to carbon7319 For This Useful Post:
    tarts1999 (18th June, 2016)
  18. #15
    LaraVAG's Avatar
    Jun 2011
    100% working solution, I send you pass by PM.
    CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
    EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
    DTC OFF, LIMP HOME MODE OFF!!!
    ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
    HOT/COLD START
    CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
    TRANSLATE DAMOS ENG
    COUNTER FIX - VAG EDC16, EDC17
    ORYGINAL FILES DATA BASE
    START/STOP ON/OFF
  19. The Following User Says Thank You to LaraVAG For This Useful Post:
