I did 2018. Working fine.
hi friends
i sell mine DSP3+ ...
What should I do? It does not read the 2019 GMC Sierra thur the obd port?? Please help! Thank you
Hi can anyone please help i have a 2004 ford F350 and f250 7.3L diesel engine im using usafullprog no option for it i looked around found that ford f150 1998-03 look almost the same but the connector vary the 1998-03 show 2plugs with 22 pins in each vs the one i found in both 2004 one connector has 22pins and other side is 2 connector with 12pins in each is this a cmm do? or maybe motorola is the option?
update i was able to do them via motorola t3 100%
no issues thanks
Nothing to do with conector.
just solder as regular bdm conection.
data ground reset 5v+
and read thru other ford with same procesor.
if you read right km then safe and wright new.
optimistic (2nd April, 2019)
no you dont
sharing is the key of success
DSP3 is a piece of junk and it's about 3 years behind. They released 3 months update and there is nothing but junk. I'm very disappointed in it. Should have saved up some money and bought something else. looks like it will die soon, like any other Chines tools. What a waste
yes the pogo pin. yet 08 silverado list says obd but no go i had to eeprom, could have done that with a 50 bucks tool , i thought dps3 would be alot more convenience however i still have more experimentals to do
rukartinatv (13th April, 2019)
