Page 51 of 63 FirstFirst ... 41464748495051525354555661 ... LastLast
Results 751 to 765 of 931
  1. #751
    drpeter's Avatar
    The Netherlands
    I updated my vagprog today and got a error code 00AA now at startup, someone had this before?
  2. #752
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by drpeter View Post
    Solved updated 5 times ok now.
  3. The Following User Says Thank You to drpeter For This Useful Post:
    MileageAudit5 (10th June, 2020)
  4. #753
    levisdj's Avatar
    EcuLand
    Touareg 2014 anyone tried obd without eeprom prepare ?
  5. #754
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by levisdj View Post
    works.....
  6. The Following User Says Thank You to Nicolas9 For This Useful Post:
    levisdj (4th November, 2019)
  7. #755
    Sep 2018
    USA
    Hello everyone. I am having an issue with my dsp3. In May of 2019 I purchased full update and all cars were unlocked. Then when I went to update a couple of months later most of my 2014-2016 cars along with other random models are now locked. Most frustrating is the Dodge ProMaster, I used to do a lot of them but then one day it turned red. Anybody else have this issue or a suggestion to fix it? Some 2018 still unlocked.
    I purchased my machine from a friend so he is still in charge of the account (contacting smelecom, buying updates etc.) but he will not help me.
  8. #756
    Quote Originally Posted by MileageAudit5 View Post
    Contact smelecom china they will help u. No machine is locked to the owner as long as you give the machine id they can help you
    Sent from my SM-N960F using Tapatalk
  9. The Following User Says Thank You to javyb For This Useful Post:
    MileageAudit5 (28th October, 2019)
  10. #757
    Sep 2018
    USA
    2018 and 2019 Toyota Camry model SE is success with smelecom dsp3. Please do not forget to read flash this before you adjust. Read flash takes about 10 minutes. Do not write flash just read flash then go back and use 1st option to read and write. Make sure soldering is good. Picture below. camry 18-19 dsp3.jpg
    If anyone needs dump file for this, let me know.
  11. The Following 2 Users Say Thank You to MileageAudit5 For This Useful Post:
    hass42 (26th January, 2020), lesther1702 (6th October, 2021)
  12. #758
    Jul 2011
    Hi, does SMELECOM DSP+ support VAG JC dashboards yet?
  13. #759
    May 2015
    someone try on 2019 ram 2500 new body with fca adaptor?
  14. #760
    Mar 2019
    usa
    Quote Originally Posted by Berubeg View Post
    that option works %100
  15. The Following User Says Thank You to optimistic For This Useful Post:
    morrisgauge (5th December, 2019)
  16. #761
    May 2015
    Optimistic also hours?
  17. #762
    Nov 2018
    Hi guys, wondering if you could help, purchased a second hand Smelecom Freezer for a BMW X3 xDrive 2.0d M Sport which was manufactured in 2019 so will be a G01 model (seller assures me that it came from the exact same car but he is a business user and will be handing has back shortly and is getting a Merc).
    Anyway fitted this morning and when pressing the B/C and Mode button both indicators flash on the dash and then after 10sec the left indicator on the dash flashes which should mean that the mileage is frozen. Took it out for a run and on checking the displays the trip mileage is frozen but the odometer still increases. If I press the B/C and Mode buttons again the right hand indicator flashes and when I start driving the odometer and trip computer operate as normal.
    The dash is a new virtual style dash only one cable behind the panel
    Any ideas where I am going wrong??
    Thanks in advance guys
  18. #763
    levisdj's Avatar
    EcuLand
    Audi A4 2016 ? Dash looks like A6 p/n 8W5920771B SW 0363 H12 , MM9COR08,07 any chance to mess it up ? Thanks
  19. #764
    Mar 2016
    Hi guys. Tried a 2006 BMW 325 (E90) today with CAS2. Cluster went fine, but my DSP3 would not do the CAS at all. Cluster plug adapter failed, so I opened it and HCs12 adapter failed. "UNKNOWN ERROR". Has anyone experienced this before? I tried a few things but ran out of time for the appointment and just put it back together.
  20. #765
    Aug 2016
    in the zone
    hello guys. i tried activating my vagprog and it keeps coming up with different errors :FAILED TO READ HARDWARE VERSION: 63, 2e, FAILED TO REFRESH FILES 2, . firmware update works, but still cannot activate because of these errors, any help
