Page 58 of 62 FirstFirst ... 84853545556575859606162 LastLast
Results 856 to 870 of 929
  1. #856
    Junior Member lesther1702's Avatar
    Oct 2021
    United States
    Hi budy how are you thanks for this picture, I have a 2018 toyota camry and I love your picture but I don’t know the pin sequence the only that I identified is the 8 because is RED but the rest I don’t know, if you can help me I will really appreciate thanks.
  2. #857
    Mar 2017
    canada
    2020 KIA KONA GAZ WORKS GREAT WITH UPDATE 2018 !!!!!!!
  3. #858
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Can anyone read a 2006 Nissan Titan using the Motorola with the T-04 or T-03 Pogo? I'm having zero luck with it. It use to work. So maybe someone on this forum may see it. Thanks in advance. The Fords still work with the pogo.
  4. #859
    Oct 2021
    United States
    Quote Originally Posted by tfourk View Post
    Hi add some picture in your post to help you, you need to create a bridge on specific location that I can show you, but you need to add a picture please.
  5. #860
    Mar 2016
    I have used the pogo pin connectors successfully. Perhaps test your pins or related connector.
  6. #861
    Nov 2021
    Hello guys. Just bought smelecom clone. Unfortunally, it ain't working. Every time it says receive data failed 08. Can someone help me?
  7. #862
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by Malakasos789 View Post
    Yes buy genuine.
    Verstuurd vanaf mijn M2101K9G met Tapatalk
  8. #863
    Mar 2017
    canada
    Today i try new update 2020 gm pickup my pickup its 2020 gmc sierra denali the update no work!!!!
  9. #864
    May 2015
    [QUOTE=MECANPRO0499;4241062]Today i try new update 2020 gm pickup my pickup its 2020 gmc sierra denali the update no work!!!!
    developped for 4" screen work on 4" only
  10. #865
    Oct 2021
    United States
    Quote Originally Posted by MECANPRO0499 View Post
    Hi in the past I do like 3 2020 Sierra including one Denali with smelecom and work perfect but has a little trick, when you connect the OBD with switch on start reading after a few minutes the cluster and the car will be off, wait a little 30 second and then push the start button again the scanner will start reading again and then you will be able to finish the car hope this helps for everyone.
  11. The Following 2 Users Say Thank You to lesther1702 For This Useful Post:
    morrisgauge (3rd December, 2021), sagie (9th April, 2022)
  12. #866
    Mar 2017
    canada
    Y TRY 2 ONE WITH 7 AND OTHER ONE 4 AND NO WORK!!!!!
  13. #867
    May 2019
    bangladash
    https://chat.whatsapp.com/GR8691CFtn64NopShIdahX
    HERE also smelecom whatsapp gruop
  14. The Following 2 Users Say Thank You to Kilometer For This Useful Post:
    javyb (23rd January, 2022), lesther1702 (23rd January, 2022)
  15. #868
    Can someone explain to me the touch holders application by number I know T's 01 is nissan but what are the rest used on hope somebody knows it was never explained
  16. #869
    W222 without filter diag option anybody had any issues using this program? Or all working great?
    Sent from my SM-F926B using Tapatalk
  17. #870
    Nov 2018
    I was bench programming a cluster thru obd using a vehicle obd adapter i made. I accidentally shorted power and ground on pins and exploded caps inside smelecom obd adapter. After repairing adapter when i boot up datasmart 3 it loads smelecom screen then datasmart screen then goes to white screen with error that i cant read. Any ideas what i could of smoked inside main unit? I dont see any faulty components visually and fuses test good
